Waveform produced by a collapsing magnetic field
32 replies · 4K views · last reply
Wow o_O
To try to begin to understand your method I drew a picture, I wondered if it agrees with what you had in mind (or whether it's completely off :wink:)? The red line is the worldline of the charge, and at ##t' = 0##, its 4-velocity is parallel to the ##t'## axis, so the charge is instantaneously at rest at this time in ##S'##. Also, the vector ##R## joining this event to ##E## is null, and thus parallel to the yellow lightcones.
Spacetime diagram with axes t and x, and primed axes t' and x' tilted relative to them. A red worldline curves from the top of the t axis down to the lower right, with a blue arrow U(t'=0) at its point of rest in the primed frame. A green vector R runs from that event up-right to point E, parallel to yellow light cone lines.
How does that look?
That's it. Thanks - I was planning to draw a Minkowski diagram myself, but got side-tracked with the simplification stuff.
Looking at that, I wonder if I've got the wrong sign on my solution for ##v##, since it should be negative. I'll have a look tomorrow.
Constant proper acceleration is also among the more complicated examples. Even Pauli got it wrong (not so Sommerfeld, but this has been overlooked for some time). I think the resolution of the paradox that apparently there seems to be no radiation is given by Griffiths in
https://arxiv.org/abs/1405.7729
https://aapt.scitation.org/doi/10.1119/1.4875195
https://doi.org/10.1119/1.4906577 (Erratum)
Also in this case there are singular contributions to the fields, because the speed of the particle goes asymptotically to ##c##, and these conributions solve the problem.
