We are in a Schwarzschild black hole-T or F?
  • Thread starter Thread starter marcus
    Schwarzschild
The discussion revolves around whether our universe can be considered a Schwarzschild black hole, particularly in relation to cosmological horizons like the Hubble radius and the cosmological event horizon. Participants debate the implications of these horizons, noting that events beyond the cosmological event horizon cannot affect us, while some suggest that our universe might exhibit properties analogous to a black hole. Fulvio Melia's work is referenced, emphasizing that while the cosmic horizon resembles a Schwarzschild surface, it does not imply we live inside a black hole. The conversation highlights the complexities of defining cosmic horizons and their significance in cosmology, ultimately concluding that the universe's structure does not fit the traditional black hole model.
Are we in a BH with one of the cosmic horizons serving as BH event horizon?
  • Total voters
    82
  • #51
All you need to ask yourself are two questions.
“Was all the mass of the universe ever contained is a radius less than R = 2GM/c2 ?”
http://en.wikipedia.org/wiki/Schwarzschild_radius
The Schwarzschild radius
If the mass collapses to a radius less than R = 2GM/c2, where G is the gravitational constant and c is the speed of light, then nothing (including light) can escape from inside this radius. It is called the event horizon or the Schwarzschild radius.
The Schwarzschild radius of an object is proportional to the mass.
Second question to ask yourself.
”Was the black hole bigger than 3 solar masses?”
http://en.wikipedia.org/wiki/Primordial_black_hole
One way to detect primordial black holes is by their Hawking radiation. All black holes are believed to emit Hawking radiation at a rate inversely proportional to their mass. Since this emission further decreases their mass, black holes with very small mass would experience runaway evaporation, creating a massive burst of radiation. A regular black hole (of about 3 solar masses) cannot lose all of its mass within the lifetime of the universe (they would take about 10^60 years to do so). However, since primordial black holes are not formed by stellar core collapse, they may be of any size. A black hole with a mass of about 1012 kg would have a lifetime about equal to the age of the universe. If such low-mass black holes were created in sufficient number in the Big Bang, we should be able to observe some of them exploding today.
Conclusion: (if the answer to the above two questions was YES), then we are still in a black hole. Or if you prefer, within the “cosmic horizon”.
Space news on Phys.org
  • #52
But as you have been told jal, you are still using an inappropriate expression,
R < \frac{2GM}{c^2},
the Schwarzschild solution, which only applies to a static spherical mass in otherwise empty space.
Unless that is you are proposing that all the mass of the universe was concentrated into a small sphere situated in an infinite and empty space, which is not the understanding of the Big Bang.
In the cosmological solution to Einstein's field equation the appropriate expression is one for density, and the question remains:
"Is \rho > \frac{{3H_0}^2}{8\pi G} or not?"
i.e. "Is the universe closed - finite and unbounded - or not?"
Garth
  • #53
Hi Garth!
Since you are advocating a different formula than that of a black hole then I will ask a clarification.
Do you support the claim, that the picture of the Cosmic Background Radiation is a picture of the universe as it was 400,000 years after the big bang?
Do you support, that when applying the energy density formula for a black hole, the result is that we are looking at the interior of a black hole?
Do you agree, that the picture of the Cosmic Background Radiation contains all of the matter of the universe?
You said,
..."the Schwarzschild solution, which only applies to a static spherical mass in otherwise empty space"...
Should not be used
By your statement, How can you justify the concept of black holes within our universe?
Everyone is using the Schwarzschild solution in their papers and everyone "knows" that a black hole is not static and is not in empty space.
You then said,
..."Unless that is you are proposing that all the mass of the universe was concentrated into a small sphere situated in an infinite and empty space, which is not the understanding of the Big Bang."
I beg to differ ... as will others.. and I do not want to divert into a discusion, which has been done too many times, "of what does the universe expand into."
  • #54
You are confusing two different solutions of the same Einstein Field Equation that are applicable to two different situations.
In the first situation all the mass is concentrated in a spherically symmetric mass set in otherwise empty space. This is the One-Body or Schwarzschild Solution.
The expression I quoted from you, R < \frac{2GM}{c^2}, is the condition on the radius of that mass for a BH.
If that condition holds then the mass would concentrate at the singularity at the centre and that radius, the Schwarzschild radius, will be the radius of the Event Horizon that forms around it.
In the second situation all the mass is spread out homogeneously and isotropically throughout the universe. This is the Cosmological Solution.
The other expression I stated, \rho > \frac{{3H_0}^2}{8\pi G}, is the condition for the Critical Density above which the universe is closed in on itself, finite and unbounded. It is sometimes called the Closure Density.
The universe is not, of course completely homogeneous, it has lumps in it, such as you. Some of those lumps of mass may satisfy the first condition in which case they will form a BH.
When I look back to the CMB I do look at all the mass (visible and invisible) on my light cone back to around 400,000 year after BB, however I am not looking into the interior of a BH, I am looking back towards the BB naked 'singularity'.
Do not confuse the two separate solutions to the Einstein Field Equation.
Garth
  • #55
The expression I quoted from you, , is the condition on the radius of that mass for a BH.
If that condition holds then the mass would concentrate at the singularity at the centre and that radius, the Schwarzschild radius will be the radius of the Event Horizon that forms around it.
Your statement is not accepted by everyone. There are numerous papers dismissing the singularity.
You are accusing me of being stubborn.
I shall return the comment by saying that you are closed minded and will not investigate a possibility that you dislike.
When applying the energy density formula for a black hole, the result is that we are looking at a picture of the Cosmic Background Radiation that shows the interior of a black hole?
The only way that you can dismiss this conclusion is by writing a paper that shows that we have somehow exited from that black hole and are now outside of the black hole looking at it from the outside.
Of course you will need to refute the papers by Fulvio Melia.
  • #56
I agree that the concept of a singularity is contentious, however as far as GR is concerned Hawking and Ellis show in The Large Scale Structure of Space-Time that there is no way of escaping a singularity at the centre of a BH, or at the beginning of the present expansion phase of the universe, if certain reasonable conditions are met.
Of course approaching the singularity itself would lead to unreasonable conditions in which it is not unreasonable to hypothesise that GR breaks down.
Nevertheless whether there are true singularities under these extreme conditions, or not, does not alter my argument and the fact that you are consistently confusing two separate solutions to Einstein's Field Equation.
In that sense I am calling you stubborn.
My comment about being a lump was not intentionally rude, the universe is not homogeneous on smaller scales. If it were not you and I would not exists, for whether you like it or not, we are both 'lumps'! :wink:
As far as FM is concerned I refer you to #47
Originally Posted by Fulvio Melia View Post
Hi Patti:
Please note that this does not mean we live inside a black hole.
Best wishes,
Fulvio
Garth
  • #57
The math says that we are in a black hole. NOT ME! SOOO... DON'T FOLLOW ME FOLLOW THE MATH.
  • #58
The math says nothing except what the physical assumptions imply.
Trace your assumptions before you take the math as saying anything.
Here, I'll help... the Schwarzschild solution presumes flat boundary conditions. This is distinct from the cosmological question where there is no boundary per se or the issue of global topology and boundary conditions is the variable in question.
BTW pleas don't "yell" i.e. all caps.
  • #59
Hi jambaugh!
My assumptions are that I have been informed correctly and that I'm lacking information.
"... and boundary conditions is the variable in question..."
I'm open for more info.
I'm aware of the the standard inflation model. (That's the one that I've been taught.)
Why is the "black hole model" not being considered?
  • #60
Assumed facts that I have learned.
There are 10^80 particles in the universe and they must fit into a sphere with a diameter of 400,000 LY.
Today, the particle sizes are approx. 10^-18m.
Question
What is the size of the particles at 400,000 years after the big bang so that they can fit into this horizon?
With my questionable calculations, I get that the particles would have had to be 2.29 times smaller than 10^-18 to fit into the size of the universe at 400,000 years after the big bang.
Therefore, as the universe expanded, from 400,000 LY, the particles would also need to expand and stopped expanding at 10^-18.
In order to get particles at 10^-18 they would have to expand and stop expanding at less than one billion years after the big bang. At that size, the universe would be big enough to contain the 10^80 particles of the standard model.
Problems
The expansion rate from 400,000 to one billion would be too fast.
Particles are not suppose to be expanding.
Those high energy particles, (smaller than 10^-18), would be creating a cascade of photons and particles, (smaller than 10^-18).
Those high energy particles do not exist in the Standard Model.
There is no mechanism to stop expansion of the particles and have the universe continuing its expansion.
Possible solutions
Add more particles between the age of 400,000 and a billion. (Merging with more black holes, Reheating.)
Move the CBR from 400,000 to a billion year.
Keep hoping to find those high energy particles that are suppose to exist below 10^-18 ---> Planck scale.
What do your calculations give you?
  • #61
As an interested amateur I have been reading
http://arxiv.org/PS_cache/arxiv/pdf/0712/0712.2865v1.pdf
NEW FRONTIERS IN COSMOLOGY AND GALAXY FORMATION:
CHALLENGES FOR THE FUTURE
Richard Ellis and Joseph Silk
18 Dec 2007
Detailed agreement between the standard model and the spectrum of fluctuations in the microwave background gives us confidence that our basic picture of structure formation is correct. It predicts the first galaxy-size halos will accrete cooling baryons to form stars by a redshift of around 20 or so. Many expect intergalactic hydrogen was reionised by the first substantial generation of star-forming low mass galaxies.
Richard Ellis and Joseph Silk said, “p. 12 The negatives are that one has no idea of the escape fraction for ionizing photons in the first galaxies and that there is at least one plausible alternative source of ionizing photons. This consists of intermediate mass black holes (IMBHs), which act as miniquasars and are prolific sources of ionizing photons at very early epochs. They must be present in considerable numbers in the early universe if one is to understand how supermassive black holes were in place by z = 6 as evidenced by the presence of ultraluminous quasars. Theoretical arguments suggest that the first generation of dissipating gas clouds at z = 10 could as easily form IMBHs as population III stars, and indeed probably form both. Confirmation of such a high redshift population of non-thermal ionising sources could eventually come from a combination of x-ray background, high-ℓ CMB and LOFAR observations. …”
It seems to me that they are advocating/proposing one of my possible solutions
  • #62
jal I thought you were saying that the universe that we are in, and can observe, is a BH in a wider universe?
If so then how does the presence of other BH's within our observable universe affect this one way or another?
Garth
  • #63
Hi Garth!
I'm only an interested amateur.
Fulvio Melia has proposed an interesting idea that results in increasing the diameter of the universe by considering the "gravity".
Richard Ellis and Joseph Silk, have also proposed an interesting idea by proposing the increase of "particles" by using black holes as the source of more "particles."
I think that if these respected astronomers are braving criticism to propose unusual solutions to try to match observations. We are living in a very interesting times and I'm glad to be witnessing it.
Of course, Richard Ellis and Joseph Silk, will have to do some "work" to demonstrate that merging black holes can fly apart and release their "particles".
If they cannot make these idea "work" then it will be interesting to see what other proposals will be forthcoming.
If you have not been following the discussion, Garrett is doing the same thing (proposing unusual solutions) to the standard model.
  • #64
Sorry jal I wasn't being 'heavy', just trying to understand what you were saying.
As I and others have said it is confusing to call the whole observable universe a 'black hole' because that is a name given to something, a gravitationally collapsed mass, within this universe.
If you want to compare the cosmological event horizon with that of a BH then a more appropriate question might be whether the total cosmological average density is greater or smaller than the critical density, if it is greater then space 'curves back on itself' and we are in a closed, finite yet unbounded universe.
As far as local BHs are concerned the radius of their event horizons are proportional to their mass, but for a fixed mass density depends on the inverse of the radius cubed.
This means that the larger the mass you have the less dense that mass has to be to form a BH.
So if you had a mass of a billion 'suns' their Schwarzschild radius would be about 1.5 x 109 kms. Gather them together and they would form a BH with an event horizon of that radius, and we might even end up in the middle of them!
However the stars would all coalesce in the middle and we would be squashed out of existence. It might be possible to gather an even larger mass and put all the stars on orbits that kept them apart for a while but I am pretty sure that after a time the same end would await them.
I myself am quite keen on the idea of modifying GR to explain some of the features of the universe and also on the idea that there might be a large number of IMBHs out there to make up missing baryonic mass, so we are not really in disagreement, I was just trying to find out what you were suggesting as 'one of your possible solutions'.
Garth
  • #65
hehehe
We are in a very interesting time.
I agree that the terminology is confusing ... Black Holes ... Cosmic Horizon ... Schwarzschild Radius ... all have the mechanism of "brick wall", once in you cannot get out.
As a result, Richard Ellis and Joseph Silk, will have to develop "the mechanism" that allows his way, (black holes), of breaking apart to distribute the "particles" contained in his black holes. (Hawkin's radiation won't do it)
Conceptually, I can think of ways that it could happen, but the "math kids" will need to proposes mechanisms that can be analysed.
I cannot find anything wrong with what Fulvio Melia has proposed. Nobody has raised any questions about any of his approach. He does make some claims that his approach is in better agreement with observations.
"So if you had a mass of a billion 'suns' their Schwarzschild radius would be about 1.5 x 109 kms. Gather them together and they would form a BH with an event horizon of that radius, and we might even end up in the middle of them! "
... and to continue the example, ... if we had a mass of 10^80 particles ... we would have a Schwarzschild radius of ?
When combining Richard Ellis and Joseph Silk, idea with Fulvio Melia, the black holes are coming from the exterior (Schwarzschild radius ) of what we call our universe ... then it raises some exciting new thinking.
hehehe
  • #66
Yes, the numbers are similar, but a too simplistic conclusion that one (cosmological event horizon) is the other (Schwarzschild radius) can lead to confusion.
Garth
  • #67
All of these proposals are to help explain the observations at z = 6.
So, something between z =1089 and z =10 and the existing Schwarzschild radius when the universe was smaller are being proposed.
Once the Schwarzschild radius is in place we do not have a mechanism to remove it.
  • #68
Continued…
http://en.wikipedia.org/wiki/Supermassive_black_hole
Supermassive black holes have some interesting properties which distinguish them from their relatively low-mass cousins:
The average density of a supermassive black hole can be very low, and may actually be lower than the density of air. This is because the Schwarzschild radius is directly proportional to mass, while density is inversely proportional to the volume. Since the volume of a spherical object (such as the event horizon of a non-rotating black hole) is directly proportional to the cube of the radius, and mass merely increases linearly, the volume increases at a greater rate than mass. Thus, density decreases for increasingly larger radii of black holes.
The tidal forces in the vicinity of the event horizon are significantly weaker. Since the central singularity is so far away from the horizon, a hypothetical astronaut traveling towards the black hole center would not experience significant tidal force until very deep into the black hole.
http://arxiv.org/abs/0705.1537
Supermassive Black Holes
Authors: Fulvio Melia
(Submitted on 10 May 2007)
These objects may have been critical to the formation of structure in the early universe, spawning bursts of star formation and nucleating proto-galactic condensations. Possibly half of all the radiation produced after the Big Bang may be attributed to them, whose number is now known to exceed 300 million.
A supermassive black hole at the nucleus of one of these distant galaxies “turns
on” when it begins to accrete stars and gas from its nearby environment; the rate at which matter is converted into energy can be as high as 10 solar masses per year.
So the character and power of a quasar depend in part on how much matter is available for consumption.
Some supermassive black holes may not be visible as quasars at all, but rather just sputter enough to become the fainter galactic nuclei in our galactic neighborhood.
By now, some 15,000 distant quasars have been found, though the actual number of supermassive black holes discovered thus far is much greater.
Because of their intrinsic brightness, the most distant quasars are seen at a time when the universe was a mere fraction of its present age, roughly one billion years after the Big Bang.
The current distance record is held by an object found with the Sloan Digital Sky Survey (SDSS), with a redshift of z = 6.3, corresponding to a time roughly 700 million years after the Big Bang.
The SDSS has shown that the number of quasars rose dramatically from a billion years after the Big Bang to a peak around 2.5 billion years later, falling off sharply at later times toward the present.
However, not all the supermassive black holes in our midst have necessarily grown through the quasar phase. Quasars typically have masses = 109 M⊙.
Yet the black hole at the center of our galaxy is barely 3.4 × 106 M⊙.
The faint X-ray background pervading the intergalactic medium has been a puzzle for many years. Unlike the cosmic microwave background radiation left over from the Big Bang, the photons in the X-ray haze are too energetic to have been produced at early times. Instead, this radiation field suggests a more recent provenance associated with a population of sources whose overall radiative output may actually dominate over everything else in the cosmos. Stars and ordinary galaxies simply do not radiate profusely at such high energy, and therefore cannot fit the suggested profile.
And so, the all-pervasive X-ray haze, in combination with the discovery of gas-obscured quasars, now point to supermassive black holes as the agents behind perhaps half of all the universe’s radiation produced after the Big Bang.
Ordinary stars no longer monopolize the power as they had for decades prior to the advent of space-based astronomy.
Quasars seem to have peaked 10 billion years ago, early in the universe’s existence. The light from galaxies, on the other hand, originated much later—after the cosmos had aged another 2 to 4 billion years.
A seed black hole might have formed in the cluster’s core. Estimates show that once formed, such an object could have doubled its mass every 40 million years, so over the age of the universe, even a modestly appointed black hole could have grown into a billion-solar-mass object. The problem is that this could not have happened in only 700 million years, when the first supermassive black holes appeared.
As I understand it.
The universe at 400,000 was too small to contain all of the 10^80 particles. The SDSS has shown that the number of quasars rose dramatically from a billion years after the Big Bang to a peak around 2.5 billion years later, falling off sharply at later times toward the present.
Supermassive Black Holes crossed the THEN “cosmic horizon” of our universe and supplied the needed 10^80 particles and increased “the gravitational cosmic horizon” to 16.9 billion years. The particle horizon is 13.7 billion years (the age NOW).
I will repeat
As a result, Richard Ellis and Joseph Silk, and Fulvio Melia or others will have to develop "the mechanism" that allows black holes to break apart and allow the "particles" contained in the black holes to spread out. (Hawkins’s radiation won't do it)
Conceptually, I can think of ways that it could be done, but the "math kids" will need to proposes mechanisms that can be analyzed.
There should be a Nobel prize for doing that and it should also lead to a way to tap into a new source of energy.
Ps. Having a “Gravitational Cosmic Horizon” would probably make it easier for the bounce models.
  • #69
jal what you have quoted about SMBHs, which may need some checking as it was taken from wikipedia, actually does not affect your basic statement.
If all you are saying is that, you cannot get out of a BH and likewise you cannot get out of this universe, then I would agree with you.
Garth
  • #70
I would have thought that you would have picked the singularity issue. :smile:
If we were to consider the singularity models as being replaceable by the bounce models then those 300 million Supermassive Black Holes, (which would not have singularities),
would be coming from outside of the THEN universe to produce half of all the radiation produced after the Big Bang. (and of course being the source of those particles which could not be there at z =1089).
All of these different models seem to tie together to help explain what we observe at z = 6.
  • #71
SMBH's form from the material from this universe that coalesced under its mutual gravitational field in the first place.
The radiation from those SMBHs also comes from the material falling into them, from the accretion disk before the event horizon is reached.
Radiation does not come 'out of' a SMBH, beyond the except for an infinitesimal amount of Hawking Radiation.
We don't know what lies at the centre, singularity or not, and we may never know because of the event horizon.
The Big Bang singularity would be different, if it is a singularity, because it is naked.
Garth
  • #72
I agree, that is what is being claimed.
Let's back up a little bit.
I did some calculations, in a previous post, and I could not get 10^80 particles into the 400,000 lyr sphere.
As a result, I question that there was enough material available to creat that radiation from those SMBHs.
I'm going to assume that my calculations are wrong and that you did your calculations and that the 10^80 particles can fit into the 400,000 lyr sphere.
Let's go over your calculations ... then we can move on and discuss on a common footing.
jal
  • #73
Where did you get 1080 particles from?
That is the approximate number of particles in the whole observable universe, not the number that would form a SMBH.
Garth
  • #74
I’m not coming up with anything new. I’m just using the information that I have learned.
Speed of light = 300,000 km/sec
Sec, min, hr, day, yr, =60*60*24*365= 525,600
300,000*525,600 = 1.58 *10 ^9 km, = 1.58 * 10^12 cm. = 1.58 * 10^27 protons (proton = 10^-15)
400,000 *(1.58 *10^27) = 6.31 *10^32 proton diameter of CBR
sphere = ( π •d³)/6 = 3.14*(6.31 *10^32)^3/6 = 3.14*(2.51*10^34)/6 = 1.314 *10^34 protons
Densest sphere packing (hex.) will only fill 74.08% of space.
Therefore, 0.7408(1.314 *10^34) = 9.73*10^33 protons in a sphere of 400,000 light years. OR there are aprox. 10^34 protons in the CBR.
Therefore, if there are 10^80 protons in the universe, there is a shortage of 10^46 protons in the universe.
Since the CBR does not reveal a hex. packing pattern, then RANDOM packing is the most likely scenario and random pack only makes up about 64 percent. As a result there would be even less protons in the CBR.
ONLY, if the SMBH came from outside of the THEN size of the universe can we end up with enough particles to make up the 10^80 estimated number of particles in the universe.
NEXT,
Possibly half of all the radiation produced after the Big Bang may be attributed to the SMBH, whose number is now known to exceed 300 million.
Who can do the calculation of how many particles are locked up in those SMBH that cannot contribute to that half of all the radiation produced after the Big Bang?
Don’t forget, if I made a calculating error, then the 10^34 protons in the CBR will not be the right starting point.
  • #75
Your maths and physics are wrong!
What do you intend by calculating the number of protons in the CMB? The CMB is a warm bath of photons.
Actually 60*60*24*365 = 3.1536x107
You seem to be calculating (incorrectly) the number of kilometres in 300,000 light years. Actually 300,000 light years is = 9.4608x1012kms = 9.4608x1017cms.
this is in metres not cms.
Wherre does the 400,000 come from?
I won't go any further, your argument is Not Even Wrong and it is Christmas Eve, I have better things to do! :wink:
Garth
P.S. If you want to find out how crowded the protons were at the Last Scattering Surface of the CMB there is an easier way.
The CMB has been red shifted by ~ 1100 since it was emitted at the LSS. This means that linear distances between representative galaxies were 1100 times smaller then.
The volume of the universe was therefore ~109 smaller than now.
The present baryon density is ~ 10-30 gm/cc which means it was ~ 10-21 gm/cc at the LSS.
This is far more rarefied than in the best laboratory vacuum, not what you would call crowded!
  • #76
jal
Garth
The point has been well made and illustrated.
I was being the "straight man". Probably will get interpreted as "an idiot".
I have already pointed out that I get my units and zeros mixed up.
I like your ps. and will include it in my blog
Of course, my calculations are wrong and need to be “fined tuned” to include the electrons because we see the CBR with The hydrogen line.
http://en.wikipedia.org/wiki/Atom
The electron is at 9.11×10-31 kg
Protons at 1.67×10-27 kg
The electron cloud
The smallest atom is helium with a radius of 31 pm, (10^-12) while the largest known is caesium at 298 pm. Although hydrogen has a lower atomic number than helium, the calculated radius of the hydrogen atom is about 70% larger.
Spectra of excited states can be used to analyze the atomic composition of distant stars. Specific light wavelengths that are contained in the observed light from stars can be separated out and related to the quantized transitions in free gas atoms.
The first atoms (complete with bound electrons) were theoretically created 380,000 years after the big bang; an epoch called recombination, when the expanding universe cooled enough to allow electrons to become attached to nuclei. Since then, atomic nuclei have been combined in stars through the process of nuclear fusion to generate atoms up to iron.
A typical star weighs about 2x10^33 Grams, which is about 1x10^57 atoms of hydrogen per star... That is a 1 followed by 57 zeros.
A typical galaxy has about 400 billion stars so that means each galaxy has 1x10^57 X 400,000,000,000 = 5x10^68 hydrogen atoms in a galaxy
There are possibly 80 billion galaxies in the Universe, so that means that there are about: 5x10^68 X 80,000,000,000 = 4x10^79 hydrogen atoms in the Universe.
http://en.wikipedia.org/wiki/21_centimeter_radiation
The hydrogen line
http://en.wikipedia.org/wiki/Timeline_of_the_Big_Bang#Recombination:_380.2C000_years
Merry Xmas
  • #77
Yep, about 1080 in the observable universe is the 'ball park' figure.
Garth
  • #78
A beating heart in a static Schwarzschild shell.
I voted for yes without giving my arguments, which after all I will give here.
1) I am convinced of a bounce preceding the expansion phase. (I think this is according Bojowald; Ashtekar).
2) Now aday’s, I.M.O. it is well accepted that the bounce domain, LQC at t=0, or even the BB in string theory, was not a point but indeed a domain containing high density.
3) If 1) is true, then there was no beginning in time ,(our observable universe did not start; t=0 is the phaseshift moment where contraction changed into expansion).
4) To me it seems not an absolute necessary condition that the maximum density, though very high, at the bounce should become as high as the Planck density.
5) I.M.O. “the cosmological principle” is a kind of boundary condition/specification (obvious very practical to use in most cosmological calculations) but certainly not a physical law. It is, to a certain degree, useful in many macroscopic considerations about our observable universe, but there are deviations and it is certainly not proven by experiments to be valid at even larger scales. Theoretically it seems me to be too big a constraint for further thinking, because it implies that the expansion of the universe is valid at all scales as an extrapolation of the experienced expansion of our observable universe.
6) I.M.O. it is very well thinkable that the cosmological principle is not exact valid at all macroscopic scales. In a kind of absolute sense from our observation site approximately yes, but in a relativistic sense no.
7) If 6) is true then it is imaginable that our verse (bounce) is not unique in space time i.o.w. it might be a concentration domain of energy (mass, black energy, dark energy and the like). See alo my thread “is our bounce unique?”
8) If 7) is true then it is very well imaginable that though the related verse is not static as a whole, its dynamic part can serve as the kernel of a BH/WH with a relative static Schwarzschild horizon. Around this kernel the density is then decreasing and very low, much lower then the density of our observable universe. We can calculate for each average density a Schwarzschild radius provided that this radius is larger then the radius of the domain in consideration and provided that a correction can be made for the influence of the surrounding environment..
I would conclude by saying I voted for yes because, with all my arguments together, I see possibilities for a universe which was never created and which will ever exist where I don’t need to accept a nonsensical nothing, a strange inflation concept or a religious argument which still puts ourselves in a central position. Some of my thoughts I saw already expressed in some posts of this thread but I felt a drive for myself to give you my own picture.
In my view I see our verse as “a beating heart within a Schwarzschild shell; this one beeing one of many in an infinite universe”
  • #79
Hurk, i like your argument! I don't see anything to disagree with (except you did not read the question of the poll carefully enough.)
Based on your argument our region of spacetime is OUT THE BACK DOOR of a black hole, so our own Hubble sphere or cosmological event horizon is NOT THE BLACK HOLE HORIZON---which is what the poll asked.
No! According to your picture, the black hole event horizon is BEFORE THE BIG BANG.
So speaking carefully, answering exactly what I asked in the poll (I phrased it carefully for this reason!) you should, by rights, have answered NO.
After the big bang space was expanding too rapidly to form a black hole and the usual horizons that people talk about (cosmological horizon and Hubble sphere) are obviously not the horizon of any black hole. Someone out there could easily exit right across them without any effort. I'm sure you understand this.
I like your picture---which is similar to Smolin's reproductive cosmology picture where black holes also lead to new expanding regions of spacetime. So I will think of you as actually answering no to the poll question as posed.
Does anyone else who originally said "Yes" want to change their opinion to "No"?
  • #80
Thanks Garth for accompanying me in this quest for information.
The big bang model has been refined for over 50 years.
Amateurs and students have probably been asking the same questions for 50 years.
All adjustments and refinements came about as a result of these kinds of questions and as a result of new observations from astronomers.
As I understand, now, the only adjustment that needs to be done, to coincide with observations, is those 300,000 million quasars, (black holes), which were formed in the early universe.
To try to answer this problem, Fulvio Melia is doing something different. He is proposing changing the age of the universe to accommodate the necessary time needed for the formation of those black holes. He is proposing two ages:
1) A particle distribution age, 13.7 Gyrs, which we can observe and
2) A Gravity age, which we cannot observe, occupying a sphere of 16.9 billion light years which would be the actual age of the universe.
Our lack of understanding of gravity at small scales, (smaller than a hair), and our inability of “seeing” if gravity is constant on all scales is the main obstacle to moving further in our understanding of the universe.
The cosmic background radiation which has been set at 400,000 years does not contain a baryon density which would indicate a black hole.
However, when doing a “look back” in an expanding universe, the baryon density would have been sufficient to have been in a Schwarzschild radius prior to 400,000 years.
Anything prior to 400,000 years (the CBR) is void of observation.
This is, therefore, another indication of our lack of understanding of gravity.
Did “mother nature” find a way out of the Schwarzschild radius?
Did “mother nature” find a way to avoid Schwarzschild radius?
OR
Is the Schwarzschild radius still there?
From our observations, we cannot detect or interpret any signs of what we understand to be a Schwarzschild radius, (a gravitational cosmic horizon).
As a result, hurk4’s description, “A beating heart in a static Schwarzschild shell” cannot be ruled out.
As an amateur I have many different questions.
Since gravity was also within the 400,000 CBR sphere and since gravity is expanding at the speed of light then as the gravity sphere gets bigger as a result, the space that the particles can occupy gets bigger.
That would imply that the expansion of the universe is due to gravity having an expanding Schwarzschild Radius.
If there was an input of 300 million Super Massive Black Holes (SMBH) after the big bang and before z = 10 then the universe would get an additional expansion phase.
Hummmm! Maybe different sizes of black holes have different properties and behave differently?
What was the Schwarzschild radius before the input of those 300,000 black holes?
Hummmm!
Maybe it was a black hole. Maybe the high energy prior to the 400,000 year was bouncing around for a long time over many cycles of bounce prior to getting an additional input of matter which would increase the Schwarzschild radius past the 400,000 light year.
With the discovery of dark energy as being the main constituent of the universe, new concepts are being considered. (Even that gravity is not a force but a geometric condition.)
Of course, with “accurate number crunching” some of these questions can be eliminated as highly improbable due to our present observations. I hope that Garth and other good “number crunchers” will stick around and help to answer some of these questions.
http://arxiv.org/abs/0712.3545
The Higgs Phenomenon in Quantum Gravity
Authors: R. Percacci
(Submitted on 20 Dec 2007)
http://arxiv.org/abs/0712.4143
Cosmological Plebanski theory
Authors: Karim Noui, Alenjandro Perez, Kevin Vandersloot
(Submitted on 26 Dec 2007)
  • #81
Hi Marcus, you are very nice.
6 times YES. Indeed I did not read the full question and restricted myself to "Are we in a Scharzschild hole?". A shame and my excuses for that!
And indeed No would have been the correct answer to a question like "Does something non existing exist?". Am I wrong if I see kind of a tautology here? In that case such an answer makes no sense. But again I might have misread your question?.
I am curious whether other people voted for yes instead of no!
kind regards
Hurk4
  • #82
I’m not ready to quit without getting a few more answers.
1) We still have not taken the effect of the mass of the neutrinos.
Garth
Would we do the same procedure for neutrinos? Is there room for all of them in a 400,000 light year sphere.
http://arxiv.org/abs/astro-ph/0607101
Neutrino masses and cosmic radiation density: Combined analysis
Steen Hannestad and Georg G. Raffelt
06 July 2006
2) We cannot leave without including some kind of number for dark energy.
http://www.physics.ucla.edu/hep/dm04/talks/yunwang.pdf
Model Model-Independent Reconstruction of Dark Energy Density
from Current Observational Data
Yun Wang
UCLA Symposium on Dark Matter & Dark Energy,
Feb 19, 2004
Being an amateur, I can only wait for the answers to the “number crunching” to see if we are within a Gravitational Cosmic Horizon.
  • #83
Thanks Hurk4,
I must sheepishly admit that the shortened headline for this thread was not the full poll question. The question on the poll had an extra condition which one could easily overlook. I hope the comments clarified this for most people.
Specal thanks to several knowledgeable commenters---Garth, Wallace, Pervect, George Jones and others---who carefully explained issues in this thread.
With Hurk's vote changed, the results are 9 Yes out of 47.
It may be that some others want to change their vote, if they are still around and learned something from the thread discussion.
The 9 who voted Yes are:
Amp1, BigFairy, daveb, jal, lightbeing, on30francisco, PaulR, PRyckman, thepassenger48
If any of you find you have second thoughts after following the discussion, please let us know.
  • #84
I voted no opinon because the question seems complex and I'm not sure the standard foundations are satisfactory to even formulate that question yet, or my own understanding is not complete enough to relate to the question.
But I think there are interesting parallells to black holes and systems considered to be "observers". The normal definition of a black hole is made relative to current models.
If we consider a black hole to be an observer, than what is a black hole? Classicaly it seems to be an observer that manages to consume new information without limiting constraint of capacity since the consumed information is added to the systems own capacity. Normally to maintain constant capacity, new information must be matched by emission of information. But it seems a black hole is so dominant that it can control and change it's environment rather than the other way around, that the observer adapts to the environment. I find this parallell fascinating, and it indeed seems to be a desirable skill - I think we all want to grow up to be black holes :) If you can learn how to control the unknown to such an extent that you can adapt any new information without making a choice on what to release.
What are valid "observers": particles? molecules? cells? organisms? solar systems? universes? What's the principal difference except the obvious: complexity?
But then when the quantum behaviour is added it gets worse. If even a black holes leaks, then it seems to suggest that it really doesn't irreversibly consume it's environment.
/Fredrik
  • #85
Vote Change
I understand from the discussion that:
The density of space would correspond to a 13.7 billion year black hole to an outside observer, but...
A black hole cannot be expanding, so our visible universe fails this second criteria.
Thus we are not in a black hole.
This leads to a few questions:
Is it just a coincidence that the density condition is met?
Does any expansion velocity disqualify or does the expansion have to be above a specific amount?
Best current guess is expansion is speeding up. If it slowed or stopped would the universe then be a black hole if it met the density?
  • #86
Hi PaulR
It is no coincidence that our observable universe has the same radius as it would if it were a black hole, because the Schwartzschild solution for a black hole is mathematically equivalent to the equation for determining the event horizon of an observable universe.
I don't think that any amount of expansion is consistent with being a black hole. As I mentioned in an earlier post, the Schwartschild solution simply isn't designed to factor in expansion, because black holes are not thought to expand.
If the universe stops expanding and collapses into a singularity, then it will come to resemble a black hole, except that as far as we know there is nothing "outside" of it, which is an obvious difference from a normal black hole.
Jon
  • #87
Jon thanks for spotting Paul's question and responding.
I agree with you.
PaulR, I got distracted with other stuff, sorry not to have gotten back earlier. I see you changed your vote so now we have 8 people who say we are in a Schwarzschild BH with some well-known horizon like the cosmological event horizon or the Hubble radius serving as black hole horizon.
Those 8 people are
Amp1, BigFairy, daveb, jal, lightbeing, on30francisco, PRyckman, thepassenger48
As I said in an earlier post, if anyone has formed a different opinion and wants to change votes that's fine, just post. I will try to catch it more promptly than last time with PaulR:smile:
  • #88
Thank you for these clarifications.
However it leads to more questions:
I don't believe it is accurate to say there is nothing outside of a 13.7 billion light year radius. That radius is only based on the time the universe has existed and the speed of light. There is no reason to believe there is "nothing" beyond that as space expansion almost guarantees there is. Thus observers could exist outside a 13.7 billion light year sphere.
I was also curious, not about the collapse of the universe, but about the condition that would occur if the universe stopped expanding, before it started collapsing. For that however brief moment would the outside observer experience this as a black hole? It would have the exact density and would not be expanding.
Last point - Could you recommend any website that would explain how "the Schwartzschild solution for a black hole is mathematically equivalent to the equation for determining the event horizon of an observable universe." I didn't realize that determining the value of 13.7 billion light years had any relation to the equation for a black hole. I just assumed it was based on observation, while the black hole density calculation was based on theory.
  • #89
It's been 9 days since I posted.
Is this thread closed?
  • #90
I never heard it suggested that the Hubble sphere, with radius c/H
was any kind of physical boundary. (except in amateur speculation)
in any standard cosmology picture the universe extends right past there without significant change.
to an observer out there 13.7 billion LY from here, things would look pretty much the same as they do here----same density of matter, same kind of galaxies, same nearly flat space.
the most distant stuff we have observed so far is now about 45.6 billion LY from us, this distance is almost the same as the 46-47 billion LY defining the "particle horizon", the most distant matter we COULD currently be observing, given ideal instruments.
I'm not sure the point of what you said, whether it contained a question, but it is indeed a commonly accepted view!
the next thing I don't understand, all observers are in the universe. there is no outside observer.
if the universe stopped expanding and prepared to collapse then we would ALL be, in effect, in a black hole :biggrin: which would NOT have 13.7 billion LY as any kind of horizon. the WHOLE KABOODLE would be destined to collapse, all observers would realize this----that they were all inside what was going to collapse.
It would not correspond to a SCHWARZSCHILD black hole. That is something with a technical meaning. The outside is permanently static from time minus infinity to time plus infinity. For eternity. So it would be incorrect to call it a Schwarzschild BH. But it would definitely be a universe on the way to a big crunch.
And this would involve a much much bigger chunk of space than our little private Hubble sphere with its radius of 13.7.
I think that's about right Paul. Someone can correct me if I've made some error. But I haven't thought much about Crunch because I don't think its in the cards.
There seems to be a consensus nowadays that the universe is on track to keep expanding indefinitely.
  • #91
Hi Jon. How do you get to this mathematical equivalence? I think it's coincidental, but would like to hear your rationale.
Jorrie
  • #92
Hi Jorrie,
I think this http://http://arxiv.org/PS_cache/arxiv/pdf/0711/0711.4181v1.pdf" answers your question, but let me know if you disagree.
Jon
  • #93
I don't think Melia actually claims that our present observable universe with presumably accelerating expansion has the same radius as it would if it were a black hole. That may have been the case without dark energy and with the deceleration parameter equaling zero.
From Melia's summary:
However, it may be that observational cosmology is not entirely consistent with
the condition R0 ≈ ct in the current epoch. If not, there must be some other reason for
this apparent coincidence. Perhaps the assumption of an infinite, homogeneous universe is incorrect.
Jorrie
  • #94
Hi Jorrie,
Hmmm, I think I had the cosmological Particle Horizon in mind rather than the Event Horizon. The correspondence of the event horizon with the Schwartzschild radius may be a "coincidence" in a certain sense, but I think it's no more coincidental than how close the size of the observable universe is to the Hubble Volume. In both cases I think the deviation is rather small because the "S" shaped expansion curve ends up close to linear curve at our epoch.
Jon
  • #95
I am still confused by this reply of 1/22/08 by Marcus.
I am trying very hard to understand the difference between a "real" black hole and a section of space where the density satisfies the Schwarzschild formula.
As I understand from the previous answers, the single other issue reuired is that the section of space not be expanding.
To verify that I understand this point, I am positing a thought experiment. If our section of space stopped expanding, would an observer outside this section then view this as a black hole? It has the proper density. If it is not expanding, is that sufficient or would some other issue come into play.
I believe the whole confusion as to whther we live in a black hole revolves around this specific point. Everyone agrees that a 13.7 billion light year sphere is exactly the radius that matches up to the actual density to satisfy that criteria. The issue is what other criteria come into play.
As a second issue, since all space is expanding, why does this expansion not also disqualify the smaller black holes, since they must also be expanding to a very slight degree.
A third issue is - is there a theoretical maximum to the size of a black hole? Can it equal or even exceed the 13.7 billion light year radius being discussed?
  • #96
PaulR said:
I believe the whole confusion as to whether we live in a black hole revolves around this specific point. Everyone agrees that a 13.7 billion light year sphere is exactly the radius that matches up to the actual density to satisfy that criteria.
Everyone does certainly not agree that our observable universe comprises a "13.7 billion light year sphere". The universe is expanding and the proper radius of our observable portion is around 46 billion light years. This then means that the actual density is far less than what is required to be a black hole. The 13.7 Gly is simply how far light could have traveled since the BB.
If only our observable universe hypothetically stops expanding (an impossibility), while the rest of the universe carries on expanding, then yes, our observable universe will start to contract and possibly become a black hole sometime in the distant future.
My view is that firstly, the expansion rate for a tiny homogeneous piece of space is so small that we cannot detect that. Secondly, a black hole is gravitationally bound and that overwhelms any small cosmic expansion that there may be.
  • #97
Hi Paul, I think your questions in your last post are good ones. You refer back to a post of mine which may have lacked clarity or said something wrong. (I'm a retired mathematician who likes cosmology, not a professional astronomer, so I'm always open to correction from the working astronomers here.) Here's an exerpt.
That is a fascinating thought experiment. In a sense Jorrie has already responded to your post, but I am intrigued by your question and I want to focus on it.
You are NOT asking what if the universe magically stopped expanding. I think you and I both agree that then we would be destined for a big crunch. There would be no center towards which we were falling. Every point would be destined to become the singularity just as in our present space every point is the point where the big bang occurred in the past. There would be no horizon and no center anywhere. Everything would look much the same except that galaxies would be BLUEshifted. and after a while we would notice an increase in CMB temperature.
You are not asking about that, you are saying what if OUR SECTION of the universe magically stopped expanding-----a Hubble ball with us as center suddenly froze and the REST CONTINUED EXPANDING. That leaves a chasm that is widening at the speed of light and it is hard for me to picture how it could be patched within the context of GR.
Before the magic, points just outside the Hubble radius would be speeding away from us at speeds slightly faster than light, and after the magic they would continue doing so.
you know if you magnify the cheese, the holes get bigger. so, if the rest continues expanding, the hole that our piece used to fill will get bigger along with everything else.
I am not sure how the thought experiment can be done (what kind of smooth geometry fills the rapidly widening gap, consistent with GR our theory of gravity?). But if it can be patched together to work in accordance with GR then I can see how you might have our erstwhile Hubble sphere, now static, sitting in the middle of a vast emptiness.
then you would have a welldefined center that things could gravitate toward. I can well believe that a suitably positioned observer could then witness something like the collapse of a star and the eventual formation of a Schwarzschild black hole (the normal endpoint of gravitational collapse).
When and where an horizon would form would necessarily depend on the details of how one filled in the gap in the geometry. (assuming it could be done consistent with GR)
When collapse is studied dynamically they don't just use the static Schwarzschild picture (which is an endpoint of a process) and there are different sorts of horizons, different equations etc. Collapse, when studied realistically, is a research area.
To respond to your other questions, that I highlighted. As far as I know there is no theoretical limit to BH size. I don't see why there would be. If the universe is spatial finite then that would seem to impose some limitation but the question is too speculative for me.
It is not the case that all space is expanding uniformly at all scales even little bitty pieces. Exansion of distances is very uneven. In some places distances are contracting. The Einstein Gr metric is dynamic and has only approximate largescale symmetries. The simplified Friedmann model is an idealization.
As I said before, to study gravitational collapse realistically uses other equations besided the static Schwarzschild metric, which is also an idealization (strictly speaking it has nothing falling into it, everything has already happened). But the upshot is that yes BHs can form and do form, even though on average largescale distances are expanding as per the Friedmann solution.
Finally there was your observation about the ALGEBRAIC COINCIDENCES. You mentioned how coincidence confuses people. That is RIGHT! It does confuse us. It raises questions in my mind too! There is the coincidence that the
hubble time is approximately the same as the age of the universe
Why should, just at this moment in history, the current value of the Hubble parameter H0 be such that
1/H0 is approximately equal to the estimated age of expansion?
That is something I would like to hear SpaceTiger or Wallace discuss some time.
I remember somebody explained it to me by drawing a picture of the scalefactor a(t) increasing with time in a curvy way (first convex then concave) and approximating it with a straight line. And I don't thing he really explained the coincidence----essentially he was just illustrating it. I think for the time being we just live with such coincidences.
Then there is a kind of additional coincidence that you pointed out: the fact that the Hubble radius at the present time, namely c/H0, is algebraically equal to the Schwarzschild radius in a completely different context-----a static endpoint of collapse to some central point. Personally I don't think that has any physical significance because the situations are so different. You often get the same algebraic formula turning up in different contexts. That is a coincidence that I feel is just run-of-the-mill and I don't expect any new physical insight to come out of it.
But the other one I do. It is fundamentally the similar to observing that at our moment of history the matter density and the "dark energy" density are roughly comparable---same order of magnitude. And I could be wrong, both or neither coincidence could turn out to be significant. maybe others have opinions about that.
anyway thanks for the interesting questions!
  • #98
"The Hubble time is approximately the same as the age of the universe".
Its very close. In principle there is energy and matter related correction factors in lambda CDM, that you can calculate starting from the Friedmann equation. For a set of different parameters you will in general get a different correction (its done numerically). Typical correction factors are like 1.5-.6, and with WMAP values, about .99.
Coincidence that this is very nearly 1? Probably, its not particularly finetuned and I see no good reason for somethign else, nor why that would be important.
  • #99
If I understand the post, I think on balance I tend to agree with you.
If the prevailing LCDM model is right then it is clearly a mere coincidence that the Hubble time and the age of the universe both happen to be about 13.7 billion years!
If the LCDM model is right, we expect the Hubble time to plateau at 16 billion years, while the age of the universe marches steadily onwards.
So when expansion is 32 billion years old, the age will be TWICE the Hubble time, instead of almost exactly equal to it. Also a mere and meaningless coincidence.
That said, it remains a bit spooky that we should just happen to be observing the world at the moment when the age and the Hubble time appear almost exactly equal. On balance I tend to discount coincidences like this, but I suppose a striking one could on occasion be a signal that our accepted models aren't getting the full picture. The coincidence which cosmologists like best to point out, as I recall, is the fact that matter density (0.27) and dark energy density (0.73) are, if we go by the standard LCDM model, roughly the same order of magnitude. According to LCDM, during much of the past matter has dominated and in the future dark energy will increasingly dominate as matter thins out. So we just happened along at about the time the rising and the falling curves crossed.
I'm not suggesting we discuss these other coincidences, certainly not in this thread. I mention them to give perspective on the topic----which is the "are we in a black hole?" confusion. At least to some people who responded in the poll, the Hubble radius of 13.7 billion lightyears looks like the Schwarzschild radius of a different situation. It may help to generalize a bit and notice that sometimes coincidences are just that. Striking but physically unimportant.
  • #100
Certainly the fact that the aotU is so close to the Hubble time is closely related to the better question of why matter and DE are on the same order of magnitude. The correction factor integral is particularly unlovely and I see no deep reason whereby you can reverse the argument and use it to generate exact cosmological parameters so that the factor is identically 1 (some hidden mechanism say), so yea probably coincidence hinging on the resolution of the other question.
As to why DE and matter are so damn close, I am less sure of. There very well could be something deeper at play there. Certainly, you can appeal to the anthropic principle to bound yourself into some interval (and that's one of the few places where its a valid argument) and that makes the 'coincidence' a little more palpable, but it is a little bit uncanny even then. Open question.
