Weight of a Fully Charged vs Discharged Battery
A fully charged battery is not significantly heavier than a discharged one, as the total number of electrons remains constant throughout the process. While there may be a minuscule difference in mass due to energy loss during discharge, this change is not measurable with standard lab equipment. The energy associated with separated charges in a battery theoretically contributes to a slight mass difference, but this is negligible in practical terms. Chemical reactions within the battery do not result in a measurable change in mass either. Overall, the consensus is that any weight difference between charged and discharged batteries is effectively unobservable.
starkind
Is a fully charged battery heavier than a discharged one? Would any difference in weight be measurable using ordinary lab equipment, such as a balance or an electronic scale?
Thanks
I can't imagine there being any difference with a sealed unit. The electrons that leave from one end come back in the other. A vented battery such as the older style automotive ones gets marginally lighter because hydrogen escapes during operation, as well as some evaporation of the water/acid mixture.
Technically, I think one should be able to argue that the work done by the battery in discharging reduces the total energy, which in turn reduces the total mass. But we are really splitting hairs here since this quantity of energy is so extremely small. I would not be surprised if it was unmeasurable with any kind of equipment
The energy in this case is an excess of electrons at the negative pole and a lack of electrons at the positive pole. I don't know if the energy states of this distribution of electrons creates more mass than a discharged battery where there's no excess or lack of electrons at either pole. I assume "charge" has no mass.
Thanks for the replies. I was in fact imagining a hypothetical sealed unit. I guess we all agree there are no more electrons in a charged cell than a discharged one? The question, then, I think, is answered pretty well. I would like some mentor confirmation to be sure. But it seems to me that the separated charges are an energy which should warp space, at least a little, and so be an effective mass, by Einstein's equation. I guess the mass in any real cell would be extremely small.
Thanks for the comments.
Hmmm. Is this technically correct?
No, it isn't; I was just simplifying to say that there is no net loss of electrons. They don't actually travel around the whole circuit. Sorry for the sloppiness. :redface:
I do not think that chemical reactions are accompanied with a change in mass. Essentially what Danger said is right, the excess of electrons at the negative terminal are transferred to the positive terminal, but they start in a chemical bond and end in a different chemical bond. Any change in mass would show up in the difference between the initial and final bond energies. Not clear to me that this exists, it certainly is not measurable with standard lab equipment.
E=mcc
Thanks
Let W(0) be the energy of the charged battery and W its energy after a given time of functioning. In accordance with the mass energy relationship the battery undergoes a change in mass DM=(W(0)-W)/cc
independent of the way in which the energy goes lost. Of course the measurement of that change is not possible at the actual technical level.
Regards
There's energy 'in' the electron configurations of the reagents in the battery. The reaction that produces a current must be releasing some energy to drive this current since the circuit has resistance. Therefore, the energy released by the battery over an operating period t is P*t where P is the mean power of the circuit.
This energy really has been 'lost' from the reagents - and specifically, it's lost from the internal energy of the electron configurations of the molecules that liberate charge. So yes, in some absolutely miniscule way, a battery will lose mass-energy as it's depleted.
Thanks everyone. I learned some things. 1. the energy in a battery is not from additonal stored electrons, as I had previously imagined. 2. potential energy from separated charges results in a very small but calculable difference in mass, in accordance with the Einstein field equations.
On to the next thing.
