How can one determine the weight of a boat submerged in water?
  • Context: Undergrad
  • Thread starter Thread starter alister718
    Boat Water Weight
The weight of a boat submerged in water can be determined by calculating the weight of the water displaced, which is equal to the buoyant force acting on the boat. The formula for buoyant force is derived from the volume of water displaced and the density of the water. It is essential to understand that the submerged volume of the boat dictates the amount of water displaced, and thus the upward buoyant force. Additionally, knowing the material of the boat is crucial for determining its weight, as the volume alone does not provide sufficient information.
  • Understanding of buoyancy and Archimedes' principle
  • Knowledge of fluid density calculations
  • Familiarity with volume measurement techniques
  • Basic physics concepts related to forces and pressure
  • Research the principles of Archimedes' principle in detail
  • Learn about fluid dynamics and its applications in buoyancy
  • Explore methods for measuring the volume of irregular objects
  • Study the relationship between material density and weight calculations
Students of physics, marine engineers, boat designers, and anyone interested in understanding the principles of buoyancy and weight determination in aquatic environments.
alister718
if i tell you that water displaced in terms of (Volume initial and Vfinal ) is Vf how would i be able (if you can) to calculate the weight of the boat?
If the boat is floating it's weight is equal to the weigth of the volume of water displaced.
If you know the volume and density of the water you have the weight of the boat.
Buoyancy has nothing to do with it?
V_f would not allow you to know the weight of the boat, It would only allow you to know the volume of the boat. You must also know the material that the boat is made from in order to find the weight.
The displaced water dictates how much upward force is exerted on the boat.
That is buoyancy. That's what buoyancy is!
In physics, buoyancy is the upward force on an object produced by the surrounding fluid (i.e., a liquid or a gas) in which it is fully, or partially immersed, due to the pressure difference of the fluid between the top and bottom of the object. The net upward buoyancy force is equal to the magnitude of the weight of fluid displaced by the body.
http://en.wikipedia.org/wiki/Buoyancy
No. Think about that a little more. Why would this tell you the volume of the boat? Most of the boat is not submerged! So the volume of water displaced is only the volume of the submerged portion of the boat...
Yes, and...? How much upward force does the floor exert on you...?
if order to do this we would need to find the height of the boat that is not submerged
Sorry, I thougt that the implication was the the boat was fully submerged. My mistake.
No, no, no, no, no.
Look at the equation for buoyant force! You only need to know one thing (that isn't a constant) and you gave it in your opening post!
A boat designed to run fully-submerged is called a "submarine"...
A boat that is not designed to run fully-submerged but is must have a hole (or holes) in it, so it's sunken displacement tells you nothing about its weight or volume.
  • · Replies 37 ·
  • · Replies 24 ·
  • · Replies 28 ·
  • · Replies 28 ·
  • · Replies 29 ·
