Trouble with Inverse Matrices - Can You Help?
  • Thread starter Thread starter Geminiben
    Inverse Matrices
The discussion revolves around difficulties with inverse matrices and their multiplication with an identity matrix. The user has attempted to find the inverse of a given matrix but is struggling to make sense of the results. They suggest that performing row operations to achieve an identity format for the first five columns may clarify the situation. There is uncertainty about whether the goal is to find the norm of specific columns, indicating a lack of clarity in the original question. Direct calculations and using a semi-identity matrix are recommended to simplify the process.
Geminiben
I think it may have to do with inverse matrices or multiplication using the identity matrix
I got the inverse of...
1,-2, 2, 2,-3
3,-5, 6, 2,-4
2,-2, 5,-4, 4
1,-3, 1, 7,-8
3,-4, 7, 0, 2
as...
-6,-14,25,20,-7
2,-13,19,14,-5
4, -2, 1, 0, 0
0, -1, 1, 1, 0
-1, 2 ,-3,-2, 1
and I premultiplied that to...
87, 57, 10,117,-101
208,232,133,330,-146
83,297,235,229, 116
154,-58,-97,112,-245
240,382,278,370, 092
But nothing really seems to make sense. Thanks if you can help!
It looks to me like it's one big giant matrix and you'd have to do the row operations to get the first 5 columns in the identity format and see what that does to the last 5 columns.
Are you looking for the norm of columns 6-10? The question isn't entirely clear to me.
Yes, you have to do raw, direct calculations. But the semi-identity matrix will make it easier
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
