Wilmer
- 307
Found this:
12-7*6+19-14=11
Add brackets only (no limit) so above is correct.
I can't do it...
12-7*6+19-14=11
I can't do it...
The order of operations, also known as PEMDAS, is used to solve this equation. It stands for Parentheses, Exponents, Multiplication and Division (from left to right), and Addition and Subtraction (from left to right).
To solve for the variable, you must first use the order of operations to simplify the equation. Then, you can isolate the variable by using inverse operations. In this case, you would subtract 19 from both sides, then divide by -1 to get the variable by itself.
Yes, the equation must be solved using the order of operations. If the equation is not solved in the correct order, the answer may be incorrect.
Yes, this equation can be solved without a calculator by following the order of operations and using basic arithmetic skills.
No, this equation only has one solution. Once the order of operations has been applied and the variable has been isolated, there is only one possible answer.
