Weird version of covariant derivative on wikipedia
GarageDweller
http://en.wikipedia.org/wiki/Four-force
At the bottom of that page, the author provides the generalization of four force in general relativity, where the partial derivative is replaced with the covariant derivative.
However if you notice on the second term in the third equality, there is a four vector summed on mu with the gamma symbols, is that there to select the 0th component of the gamma symbol? Since in a MCRF frame, the spatial components of U are all 0.
That's because it's not really the covariant derivative. It's the absolute derivative, which is the covariant derivative taken along the particle's world line. That is,
Fλ = DPλ/Dτ = PλUμ
In special relativity, the chain rule gives
\frac{d}{d\tau} = \frac{dx^\alpha}{d\tau} \frac{\partial}{\partial x^\alpha} = U^\alpha \frac{\partial}{\partial x^\alpha}.
In general relativity, the partial derivative have to be replace by covariant derivatives, so
U^\alpha \nabla_{\partial_\alpha},
and
U^\alpha \nabla_{\partial_\alpha} = \nabla_{U^\alpha \partial_\alpha} = \nabla_{U}
Differentiating with respect to proper time is replaced by a covariant directional derivative in the direction of the 4-velocity.
[edit]didn't see Bill_K's post[/edit]
Um because proper time is the parameter of the world line that the four velocity is tangent to?
Just a comment: the distinction isn't Special Relativity vs General Relativity, it's inertial, cartesian coordinates vs. noninertial, curvilinear coordinates.
The covariant derivative must be used whenever the basis vectors vary from place to place. That can be due to spacetime curvature, but it can also be due to using curvilinear coordinates.
For example, let's do ordinary Newtonian physics in 2D space. We have a particle whose position as a function of time is given by x=A, y=vt where A and v are constants. So this is just constant-velocity motion. The velocity vector U is given by U^x = 0, U^y = v.
Now, in terms of polar coordinates r and \theta, the same motion looks like:
U^r = \dfrac{dr}{dt} = \dfrac{v^2 t}{r}
U^\theta = \dfrac{d \theta}{dt} = \dfrac{A\ v}{r^2}
That doesn't look like "constant velocity" at all:
\dfrac{dU^r}{dt} = \dfrac{v^2 (r^2 - (v t)^2)}{r^3} = \dfrac{v^2 A^2}{r^3}
\dfrac{dU^\theta}{dt} = \dfrac{- A v^3 t}{r^4}
But it is constant, if you use covariant derivatives, with
\Gamma^r_{r r} = 0
\Gamma^r_{r \theta} = 0
\Gamma^r_{\theta r} = 0
\Gamma^r_{\theta \theta} = -r
\Gamma^\theta_{r r} = 0
\Gamma^\theta_{r \theta} = \dfrac{1}{r}
\Gamma^\theta_{\theta r} = \dfrac{1}{r}
\Gamma^\theta_{\theta \theta} = 0
Yes, good point.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
