Understanding the Trough Problem: 10ft Pipe with Isoceles Triangle Ends
  • Thread starter Thread starter JasonRox
The discussion revolves around understanding a trough shaped like a prism with isosceles triangle ends, measuring 10 feet in length, 3 feet across the top, and 1 foot in height. Participants clarify that a trough is essentially a container with a constant cross-section, which in this case is a triangle. There is confusion about the geometry, with some thinking of it as a pipe with additional conical ends, but the consensus is that it is a triangular prism. The dimensions indicate that the triangular cross-section is 3 feet wide at the top and 1 foot tall. Overall, the conversation seeks clarity on the geometric properties of this specific trough design.
JasonRox
Homework Helper
This is the beginning of a question and I have NO clue what the hell they are talking about.
A trough is 10ft long and its ends have the shape of isoceles triangles that are 3ft across at the top and have a height of 1ft.
This is just the beginning of the question. I looked up what trough is and I found it to be some sort of pipe.
I can't solve the problem without this.
I'm thinking of a pipe that is 10 feet long and 1 feet high. That is the volume of a cylinder. Plus, 2 cones on the tips of some kind. I really don't know.
Any help?
Mathematics news on Phys.org
A trough is, erm, something that farm animals eat out of, amongst other things. Just imagine you've got a container that is prism of constant cross section (the triangle) and of length 10ft. That is the trough.
Feet? Oh well. Never mind.
take a long section of pipe with a triangular cross section. remove one of the sides and you'll have your trough.
Like this...
..\_________/
...is that it?
3 feet across the top, from what?
Yes that would be a trough, I would say the distance between the top corner of the trough to the other top corner is 3 feet.
In other words, the trough is 1 feet tall.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
