What are balance input impedence
  • Thread starter Thread starter dhool3053
    Balance Input
Input impedance is crucial for effective voltage and current transfer between devices, particularly in audio circuits where a high input impedance ensures minimal current flow and maximum voltage transfer. In power circuits, the focus shifts to maximum power transfer efficiency rather than voltage, with input impedance only slightly higher than the output resistance. RF circuits require precise impedance matching to prevent signal loss and reflections. The term "balance" typically refers to equal power distribution in audio systems, maintaining a realistic sound stage. Clarity in terminology is essential for productive discussions on this topic.
dhool3053
lm doing an assignment regarding resistance may caused an error in the magnitude of the output voltage.
You can't possibly expect a productive reply based on a post like yours can you?
input impedance refers to an impedance value designed or set to result in a desired transfer of voltage or current to one device/circuit from another source.
For instance, in audio circuits 'good' input impedance usually means that as seen from the terminals where another output device is to be hooked up to it, the effective resistance of the input circuit of a device is 100 or more times the internal resistance seen backward at the output terminals of the source device. This ensures that little current flows, but maximum voltage transfer is achieved between the source and input of the next device.
In power circuits, the ideal impedance is based upon maximum power transfer or maximum efficiency of power transfer, *NOT* maximum voltage. Here quality of the signal is not important but direct transfer of energy is the key idea. So here, you might find that the internal impedance of the input circuit is only a bit higher than the output terminal internal resistance.
In RF (radio frequency) circuits again the goal is slightly different. Impedance must be exactly matched between source and sink so that there is no residual reflection or waste of power or loss of signal.
Balance usually refers to equality of power or centralized perceived direction of sound in a stereo or quadraphonic (or 5 way) speaker system. It results from roughly matching the overall power output from each speaker so that a stereo image is maintained and the sound is evenly distributed to the listening area and results in a realistic illusion of the original sound-stage.
You have a point: my response was productive, but will it be understood by someone who can't string a sentence together?
Nice writeup Nam. The OP's use of the word "balance" confused me, so I waited to try to reply. I couldn't tell if he meant balanced versus unbalanced transmission lines, or matched impedances or whatever. (I didn't even think of the audio multi-channel balance angle...) Hopefully your answer helps him.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
  • · Replies 20 ·
