What Are Closed Timelike Curves?
  • Thread starter Thread starter Champion
    Closed Curves
Champion
i was going over some relativity search online and came across what is called a closed timelike curve and that i actually allows time travel, am i right?
A "curve" is a function c:A\rightarrow M where A is some interval of real numbers and M is the spacetime manifold. "Timelike" means that if we call the tangent vector v and the metric tensor g, then g(v,v)<0 at all points on the curve. (If we define the metric with a +--- signature instead of -+++, it's ">" instead of "<"). "Closed" means that c(t+T)=c(t) for some real numbers t and T such that both t and t+T are in A.
A timelike curve is the type of curve that can represent that path of a massive object through spacetime. If it's closed, the object will meet a younger version of itself at some point.
Edit: I should probably add that the condition g(v,v)<0 can also be written
g_{\mu\nu}v^\mu v^\nu&lt;0
and that in a local inertial frame, this is just
-(v^0)^2+(v^1)^2+(v^2)^2+(v^3)^2&lt;0
i was thinking it over,about the constant energy.ctc's would violate 2nd law of therodynamics,also i looked up that GR allows ctc's but QM does not.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
