What Are Heuristics (in Math)?
  • Thread starter Thread starter SF49erfan
Heuristics in mathematics refer to experience-based techniques that aid in problem-solving and decision-making, providing solutions that may not be optimal but are satisfactory. These methods help reduce cognitive load by using mental shortcuts, such as rules of thumb or educated guesses. For instance, when dealing with shapes, the figure with the largest area for a given perimeter is a circle, while a square maximizes area among four-sided polygons. Additionally, applying trigonometry often involves identifying triangles, particularly right triangles, in geometric problems. Resources like "How to Solve It" by George Polya offer valuable insights into problem-solving strategies and heuristics.
SF49erfan
Some math advice/tips guides say that having a knowledge of heuristics can assist with mathematical problem-solving.
I'm trying to get better at the subject over the summer before my first year of uni coming in the fall. I don't think, however, that I know what is meant when people use the term "heuristics." I'm wondering if someone wouldn't mind with a definition of this term and perhaps an example?
Greatly appreciate your help! TVM.
Mathematics news on Phys.org
You are asking for the definition of a word. Is there a reason why you could not look it up yourself?
Checking Wikipedia gives:
Heuristic (Template:(IPAc-en); Greek: "Εὑρίσκω", "find" or "discover") refers to experience-based techniques for problem solving, learning, and discovery that give a solution which is not guaranteed to be optimal. Where the exhaustive search is impractical, heuristic methods are used to speed up the process of finding a satisfactory solution via mental shortcuts to ease the cognitive load of making a decision. Examples of this method include using a rule of thumb, an educated guess, an intuitive judgment, stereotyping, or common sense.
In more precise terms, heuristics are strategies using readily accessible, though loosely applicable, information to control problem solving in human beings and machines.
For example, figures with a given perimeter tend to have the most symmetrical shape that is allowed by other constraints. The plane figure with largest are for a given perimeter is a circle. The 4 sided polygon with largest area for a given perimeter is a square.
Another example, applying trigonometry to geometry problems tends to involve triangles, especially right triangles. So if you are tyring to figure out the length of a line segment in a diagram you should look for triangles. If you don' see any you should extend lines in the figure to make triangles and draw lines perpendicular to other lines to attempt to form right triangles.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
