What are the best materials for underground heat insulation plates?
The discussion focuses on the best materials for underground heat insulation plates, specifically recommending HDPE sheets and Phenolic materials for their effectiveness in heat insulation. Participants highlight the advantages of foam insulation over solid materials and suggest ceramic fabrics, such as glass fibers, as viable options. Additionally, traditional materials like cork, wood, and various plastics are mentioned, emphasizing the importance of assessing long-term heat and stress resistance.
  • Understanding of thermal insulation properties
  • Familiarity with materials like HDPE and Phenolic
  • Knowledge of foam versus solid insulation techniques
  • Basic concepts of heat transfer and resistance
  • Research the thermal properties of HDPE sheets
  • Explore the benefits of Phenolic insulation in construction
  • Learn about the effectiveness of foam insulation materials
  • Investigate the use of ceramic fabrics in heat insulation applications
Construction engineers, architects, and anyone involved in designing underground utility systems requiring effective heat insulation solutions.
bagel_68
Hi
I am looking for some thin and light heat insulation materials probably in a flat plate form.
We intend to install this kind of heat insulation plate underground for separating different utilities.
Any suggestion ?
Thanks a lot.
What about a poly? Like sheets of HDPE? What kind of heat are we talking I guess I should ask first? You could use sheets of Phenolic too! It works great for insulating heat! We use it for spacing intake manifolds from cylinder heads and it reduces transferring to the intake manifold.
Foams insulate better than plain solids do, provided they fit your use.
You may also look at fabrics of ceramic, like glass fibres.
As plain solids, you have cork, wood, and plastics, yes. Plastics conduct nearly all the same, so check the long-term resistance to heat and stress.
  • · Replies 16 ·
