What are the chemical reaction happen indise lamp in tungsten
In incandescent lamps with tungsten filaments, the metal heats up to produce light without undergoing chemical reactions. However, in halogen lamps, iodine is added to the gas surrounding the filament, which reacts with tungsten at cooler quartz surfaces to form tungsten iodide. This tungsten iodide vaporizes and returns to the filament, where it decomposes back into tungsten and iodine, enhancing the lamp's longevity and allowing for higher operating temperatures. The discussion also touches on the Van Arkel-de Boer method as a related topic. Understanding these processes is crucial for grasping how halogen lamps function compared to traditional incandescent bulbs.
kimdesug
Also the chemical involve in the W and iodine. Thx
Welcome to PF.
Your question is unclear.
Do you mean an incandescent lamp with a tungsten filament?
There are no chemical reactions to make the filament glow - the metal heats up until it glows. Reactions with air will reduce the lifetime of the bulb so we want to avoid them.
Don't know what you mean by "in the W and iodine".
I suppose he refers to halogen lamps. There some halogen like iodine is added to the gas surrounding the filament. It reacts with the tungsten at the cooler quartz surface (which still has some hundred degrees centigrade) to form tungsten iodide which vaporizes and diffuses back to the filament where it decomposes again into tungsten and elementary iodide. This helps to prolong the livetime of the lamp and use them at higher filament temperatures.
PS: Maybe more adequate to be discussed in the chemistry forum
sorry for unclear question, I want to know what happen in the incandescent lamp which add 0.1 mg of iodine. Thx for DrDu, I can picture something.
You may also look for: Van Arkel - de Boer method
thank!
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
