What are the Functions of VFD Control Circuits?
The discussion centers on the functions of Variable Frequency Drive (VFD) control circuits, specifically in the context of reconnecting and programming a duplex control panel for a water booster system. The user seeks guidance on understanding the I/O terminals of a new drive, comparing it to an older model. Key advice includes obtaining the drive manuals for both the old and new drives, as parameters may vary significantly between models, despite similarities in motor performance.
  • Understanding of Variable Frequency Drives (VFDs)
  • Familiarity with control circuit wiring and programming
  • Access to drive manuals for both old and new models
  • Basic knowledge of motor performance parameters
  • Research the specific I/O terminal functions for the new VFD model
  • Learn how to copy program parameters from the old VFD
  • Explore programming techniques for duplex control panels
  • Investigate common VFD troubleshooting methods
Electrical engineers, technicians working with VFDs, and anyone involved in the installation or programming of control circuits for water booster systems will benefit from this discussion.
gutierrjg
Hi,
I,m Novice on VFDs and I was called to reconnect control circuits and program one of them for a duplex control panel(water booster system). I figured out the I/O terminals on the new drive but don't know it functions. Where I can get those function from since the only source is the old drive from other manufacture next to it?
Any suggestion will be appreciated.
Thanks
You should have the drive manual for both the old and the new- Google it, I am sure it is out there somewhere. Otherwise your question is too general for us to be much help.
The parameters for each drive will be similar for the motor performance, but the control and IO can be different. For the old one look for some method to make a copy (file) of the program / parameters.
Thanks , I already have the old drive manual. I guess looking at its function I will be able to program the new one.
Thanks again
  • · Replies 67 ·
