What are the Hamilton equations of motion
Hamilton's equations of motion describe the deterministic evolution of a system in phase space and are applicable across various fields of physics, not just classical mechanics. The equations relate the time derivatives of position and momentum to the partial derivatives of the Hamiltonian function, H, which incorporates both position and momentum variables. Common forms of the Hamiltonian include expressions for Newtonian gravity and classical electrodynamics, illustrating its versatility. In general relativity, the Hamiltonian becomes more complex, reflecting the intricacies of the theory. Overall, Hamilton's equations are fundamental to understanding conservative systems in physics.
Definition/Summary
Hamilton's equations of motion is a very general equation of a system evolving deterministically in phase space.
Equations
\left( {\begin{array}{*{20}{c}}<br /> {\dot q}\\<br /> {\dot p}<br /> \end{array}} \right) = \left( {\begin{array}{*{20}{c}}<br /> 0&amp;1\\<br /> { - 1}&amp;0<br /> \end{array}} \right)\left( {\begin{array}{*{20}{c}}<br /> {\partial H/\partial q}\\<br /> {\partial H/\partial p}<br /> \end{array}} \right)
Extended explanation
A common misconception is that Hamilton's equations is only applicable in classical mechanics (celestial mechanics and elastic mechanics). Although this may have once been true, it has found applications everywhere in physics. It applies in almost every conservative system in classical (deterministic) physics. The meat of Hamilton's equations is given by the function H (the 'Hamiltonian'). This is a real function given by position variables and momenta variables with continuous second partial derivatives.
In Newtonian gravity, the Hamiltonian may be given as
H = \frac{{{p^2}}}{{2}} - \phi
Here, phi is the gravitational potential. Mass is taken to be unity.
In classical electrodynamics, the Hamiltonian may be given as
H = \frac{1}{2}{\left( {{\bf{p}} - e{\bf{A}}} \right)^2} + e\phi
Here, e is electric charge, phi is now the electric potential, and A is the magnetic vector potential. Mass is again taken to be unity.
In general relativity, the expression of the Hamiltonian function gets far more complicated.
* This entry is from our old Library feature. If you know who wrote it, please let us know so we can attribute a writer. Thanks!
That's really interesting! It's great to know that Hamilton's equations are applicable to many different systems, from Newtonian gravity to classical electrodynamics. It's really amazing to think about how far this equation has come and all the different areas in physics it applies to.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
