What are the speeds of two Jupiter sized planets when they collide?
The discussion focuses on calculating the speeds of two Jupiter-sized planets colliding after being released from rest 1.0 x 10^11 m apart. Key points include the need to use the distance between their centers for gravitational calculations and that the potential energy of the system changes into kinetic energy as they collide. The gravitational potential energy is calculated using the formula Ug = -Gm1m2/r, and the kinetic energy is derived from the total energy of both planets. Clarifications were sought regarding the inclusion of radii in calculations and how kinetic energy is distributed between the two planets. Ultimately, the correct speed of the planets upon collision is determined to be approximately 3 x 10^4 m/s.
AbigailG
Two Jupiter sized planets are released from rest 1.0 X 10^11 m apart. What are their speeds as they crash together?
I think my problem lies in figuring out which radius to use. In an equation like this are the radii of the planets included in the distance between them given? If not, should it be?
[/B]
Ug = -Gm1m2/r
r (Jupiter) = 6.99 x 10^7 m
m (Jupiter) = 1.9 x 10^27 kg
r (between) = 1.0 X 10^11 m
[/B]
Using conservation of energy:
Ei = Ef
Question #1 -- Ei is entirely Ugi...is it 2(Ug) ?
Ef = K + Ugf
Question #2 -- Is there still gravitational potential here? And if so is the radius used equal to twice the radius of Jupiter?
Question #3 -- Is the kinetic energy found for both of the planets or just one?
I need clarification on quite a few points, I apologize...but i feel like once I understand this fully I will be able to work it out myself.
For spherical objects, the distance you want to use for gravitational calculations is the distance between their centers.
Make a drawing showing the initial and final configurations. Indicate the separation between the planet centers for each situation.
The system as a whole (the system being both planets) has gravitational potential energy. You are looking for the change in potential energy between the starting configuration and the ending configuration. That change in potential energy will show up as kinetic energy for the whole system. You need to decide how that energy will be split between the components of the system.
Compare the radii of the planets with their initial distance apart. Does it matter? (The distance is usually between their centers.)
The potential energy is of the two-planet system; the formula quoted is all of it.
The distance between them when they crash will equal twice the radius.
Again, the energy is of the system -- so it is the total KE of both.
(gneill beat me to it!)
Okay, so I have:
Kf - Ugf = Ugi Where: Ugi = -Gm1m2/r(between) and Ugf = -Gm1m2/2r(Jupiter)
1/2(m1+m2)-Ugf = Ugi
v = sqrt((2(ugi+ugf)/(m1+m2))
= 3 x 10^4 m/s
This is the correct answer. But why did I not have to divide the velocity amongst the two masses? Is it because I divided by the sum of the masses?
AbigailG said:
Kf - Ugf = Ugi
That should be a + sign.
You left out the v^2 in your KE term. Note that your first term is the total KE of both planets!
You already included that "sharing" when you wrote the total KE earlier.
Doc Al said:
That should be a + sign.You left out the v^2 in your KE term. Note that your first term is the total KE of both planets!You already included that "sharing" when you wrote the total KE earlier.
Oops, just a typo. Sorry.
Thank you so much! I appreciate your help.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
