What Could Be Causing Negative Reactive Power in a Three Phase Power System?
2 replies · 3K views · last reply
Nick Kuza
In a three phase power system,delta connected 66kV transmission line,the reactive power in one of the line/phase is negative(capacitive) while the reactive power in the other two lines/phases is positive.What is causing the reactive power to be negative(capacitive) in this phase?What are some possible solutions towards mitigating this negative(capacitive) reactive power?
Welcome to Physics Forums.
Adding capacitors will decrease the Vars, adding inductors will increase the Vars, or you can use the what's called a Synchronous Condenser which will either increase or decrease Vars.
In electrical engineering, a synchronous condenser (sometimes called a synchronous capacitor or synchronous compensator) is a device identical to a synchronous motor, whose shaft is not connected to anything but spins freely.[1] Its purpose is not to convert electric power to mechanical power or vice versa, but to adjust conditions on the electric power transmission grid. Its field is controlled by a voltage regulator to either generate or absorb reactive power as needed to adjust the grid's voltage, or to improve power factor.
This could be caused by many things - How much are you talking about? How many VAR relative to Watts, if it is a small amount(near unity - or very low real power flowing) this could be a "normal" system condition, one line is actually more capacitive than the other lines. However is it is a significant amount of VARs at significant power - I would check that the CTs/PTs , instruments are connected properly. Is the POWER in that leg reversed as well?
What device is being used to tell you that the PF is +/-? Is there any way to get a complete vector diagram of the readings.
