What distance does the boat move
  • Thread starter Thread starter misstoi21
    Boat
The discussion revolves around a physics problem involving a boy moving from the stern to the bow of a boat and calculating the distance the boat moves in response. Participants emphasize the importance of the center of mass remaining at rest, leading to the conclusion that the movement of the boy results in an equal and opposite movement of the boat. The formula for calculating the center of mass is shared, highlighting the relationship between the masses of the boy and the boat. There is also a suggestion to avoid creating new threads for replies to maintain organization. Overall, the conversation focuses on applying physics principles to solve the problem effectively.
misstoi21
The mass of a boat is M=80kg, the mass of a boy is m=36kg. The boy moves from the stern to the bows of the boat. What distance does the boat move, if its length is 2.8m? At such low speeds the water resistance may be neglected. Hint: Center of mass remains at rest.
Please help me because I am stumped :confused:
This question is best suited for the Homework help section.
Why not try your own hint? Calculate the center of mass (with respect to the boat) of the boat&boy in these two cases:
(1) Boy at stern
(2) Boy at bow
What must have happened?
Hasn't there been a question just like this at least twice in the past week or so?
cookiemonster
I thought so too, cookiemonster. See if you can find it.
Well, I can't find them, so here we go again.
Do you have an equation to find the center of mass of two objects, misstoi21? What is it? What would it be for when the boy is at the stern and what would it be for when the boy is at the bow? Don't these two have to be equal?
Also, please don't make a new thread in order to post a reply. Please use the "Post Reply" button at the bottom of the page.
cookiemonster
The formula for centre of mass is something like this
d = \frac{m_1d_1 + m_2d_2}{m_1 + m_2}
d, d1, and d1 are all relative to a given point. I think you have to assume that the centre of mass for the boat is in half-way between the front and back of the boat.
On second thought it could just be an inertia thing like this
m_1 \Delta d_1 + m_2 \Delta d_2 = 0
I'll work on this a bit more.
Ok instead of trying to figure out some formula then get a value then plug it into another formula, just make 1 giant formula.
d does not change
d = d'
So then switch that around once
d - d' = 0
Sub it in once
\frac{m_1d_1 + m_2d_2}{m_1 +m_2} - \frac{m_1d_1' + m_2d_2'}{m_1 + m_2} = 0
\frac{m_1d_1 - m_1d_1' + m_2d_2 - m_2d_2'}{m_1 + m_2} = 0
\frac{m_1 \Delta d_1 + m_2 \Delta d_2}{m_1 + m_2} = 0
Since the denominator will never affect whether it is zero or not, it can just be cut out of the equation.
That's the same equation I had above which shows that inertia is conserved. How awesome is that? :smile:
Actually, the location of the center of mass of the boat is irrelevant. Its change will be the same regardless of where it is.
cookiemonster
can anybody send or give me the address of a good site where I can find some good A level notes?about any topic.
Thank you
