What Do E, V, and e Mean in Voltage Symbols?
  • Thread starter Thread starter Line
    Voltage
13 replies · 5K views
Line
Throughout EE I've seen many symbols. When it comes to voltage I've seen E,V,and e. Do they all mean the same thing?
E is generally used for electric field
V or v is generally used for voltage
e generally refers to an electron or the constant from natural logs
In the book I've been readinf E means potential difference.
And e was in one about Industion. Eqaution looked something like
L=de/dt
Sounds like your book has problems. What are the title and author of the book? Potential difference is voltage V, and [tex]E = - \nabla V[/tex]
E can be used for electromotive force which is equivalent to voltage right?
If you're counting V is the actual voltage and Eis the voltage with ground
calculated then [tex]E=V- \nabla V[/tex] ...potential difference.
Here we use U for the voltage and sometimes E for the EMK.
We use V to symbolize the potential difference.
e should be the time dependent voltage (of course we use u for that).
Holy smokes, that's totally wrong and misleading. Try putting units into that equation...
Potential DIfference does eqaul voltage minus the change in voltage doesn't it?
IN my boo E was potential difference, V was voltage and e had to do with induction.
e=N x d(webers)/dt
It can, but that's not what you wrote. There's a big difference between [tex]\nabla[/tex] and [tex]\Delta[/tex] :smile:
FYI, [tex]\Delta[/tex] can represent a change (as I guess you intended), but [tex]\nabla[/tex] is the gradient operator. So the equation [tex]E = -\nabla V[/tex] is the way that we usually show the relationship between the vector electric field E and the scalar potential V.
In the beginning of the book they teach us E as the voltage.
I=E/R
Then in the middle they give us V.
P=VV/R
You are correct, E can be used for http://www.phys.uAlberta.ca/~gingrich/phys395/notes/node8.html .
As Berkeman has also mentioned, E (especially boldface) is also used in electrical engineering for "electric field", so be careful of the context in which you are using these symbols.
I=E/R
P=VV/R
So in your book, they are using E interchangably with V for voltage potential. (they are virtually synonymous).
Sounds to me you have a terrible book, Line.
