What does the equation xy=k represent?
  • Thread starter Thread starter svigneshkumars
The equation xy=k represents a relationship where x and y are variables, and k is a constant. This can be interpreted as a function f(x, y) = k, where the output is the product of the inputs x and y. When solved for y, it reveals an inverse variation, expressed as y = k/x. The graphical representation of this equation is a hyperbola, indicating that as one variable increases, the other decreases. Overall, the interpretation of the equation can vary based on the context of the variables involved.
svigneshkumars
What does the eqn xy=k represent?
Mathematics news on Phys.org
It depends upon the interpretation of your symbols x,y and k.
In many cases, that will represent a function (though I'm used to seeing z insteak of k.)
f(x, y) = k. In your case, f(x, y) takes the two inputs (x and y, obviously) and multiplies them together. k is called the output, x and y are inputs. Most people will remember seeing f(x) = y in high school, in this case f() has two variables intead of one. As Arlidno mentions, the interpretation will vary. x may represent height and y may represent width, hence k would represent the area of a square-ish object.
Well, if you solve it for y, then you get: y = k/x. This is an inverse variation.
It could be as simple as that.
Assuming x and y are variables and k is a constant, the graph will be a hyperbola.
Assuming "xy" is a constant, the k-graph is either a straight line, assuming a (k,l)-coordinate system to speak out from.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
