What does the moment of inertia depend on?
The moment of inertia depends on several key factors: the mass of the object, its shape, and the location of the axis of rotation. The distribution of mass is crucial, as it affects how the moment of inertia is calculated. Angular velocity is not a factor in determining moment of inertia; rather, it is a variable that influences angular acceleration. The moment of inertia is defined as the resistance to changes in angular acceleration. Understanding these dependencies is essential for analyzing rotational dynamics.
Meowzers
-Angular velocity
-Shape of the object
-Location of axis of rotation
-Mass
Well, I think the location of the axis of rotation matters because it sets a reference point. I'm not sure about the others. Doesn't it also depend on how the mass of the object is distributed? So would that be the mass or shape of the object, or both? Also, moment of inertia was defined to be the resistance to the change of angular acceleration. But does that mean that it's dependent on the angular velocity?
Am I missing anything from above or incorrectly included any?
Look up the definition of moment of inertia, it will provide you a direct answer instantly.
yes if i remember correctly they are all factors of the moment of inertia except for the angular velocity which is a variable
