What doesn't have gravitational mass?
Usaf Moji
Is there anything in the universe that doesn't have gravitational mass? My understanding is that both rest mass and "relativistic mass" are gravitational masses, i.e. both are subject to the force of gravity. Further everything must have at least one or the other (if not both). Anything that doesn't have rest mass must move at the speed of light in order to exist in our universe. This in turn gives it a relativistic mass.
Is my reasoning correct? (be gentle:o))
Hi Usaf Moji! :smile:
Yes … energy has mass (or energy is mass), so anything with energy of any sort has gravitational mass.
(Assuming, of course, that gravitational mass and inertial mass are the same. :rolleyes:)
And it's difficult to imagine anything without energy. :smile:
In general relativity, the concept of "gravitational mass" is not fundamental. The effects of gravity are described using the curvature of spacetime.
The curvature of spacetime is determined by the stress-energy tensor, whose components at each spacetime point are derived from the energy and momentum density at that point.
I'm not an expert in GR by any means, but I understand from reading various threads here that one can define various kinds of "gravitational mass" for an extended object, depending on which gravitational effects you're interested in. In some cases these do reduce to what we call "relativistic mass" in special relativity, but it is dangerous to use "relativistic mass" blindly as "gravitational mass."
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
