What Factors Affect the Torque on a Circular Current Loop?
8 replies · 19K views · last reply
Bubofthedead
Note getting the right answer.
Question:
a). What is the magnitude of the torque on the circular current loop in the figure?
b). What is the loop's equilibrium position.
Torque = [(I*A)*B*(sin(theta))]
L= 2.0cm
a= 2.0mm
Iwire = 2.0A
Iloop = 0.20A
First, I tried to find theta using tan^-1(x/y).
Second, I tried to find B, using B= [(1.257E-6T*(m/A)*(I)] /(2*pi*r).
Finally, I tried Torque = [(I*A)*B*(sin(theta))].
  • Diagram of a long straight wire carrying current I1 (dot, out of page) at left, a distance L from a rectangular loop carrying current I2 at right, with side length a marked; loop's top side shows a cross (into page) and bottom side a dot (out of page).
Not sure what you did here. Theta is the angle between the field from the wire and the magnetic moment of the loop (which is perpendicular to the loop).
Looks OK.
So my angle is 90deg, and I didn't need to solve for it?
What did you use for r? It's not L, you have to use the pythagorean theorem with L and a as your legs.
For r, I did the square root of [(L)^2+(a/2)^2].
OK good, you've got that. Maybe:
1) Did you account for both torques, one for each wire in the loop?
2) Did you use the correct area for the loop?
3) Are the directions correct? I think the force on the bottom piece would be up and to the left, and the force on the top would be up and to the right..
If not that I can't see what else might be wrong.
1). Aren't both torques the same, so I would double it?
2). Isn't the area A= [(pi)*(R)^2]?
3). I don't think direction is important, because it just wants the magnitude of torque.
Let me know I made any bad assumptions on these 3.
**Also, can someone confirm that the angle in my calculation for Torque = [(I*A)*B*(sin(theta))] is 90deg because of the figure being perpendicular.
Thanks so far
Still could use a reply, to my last post (especially about the 90deg).
Thanks
I wouldn't bother with that, since the distance from wire to loop segment varies along the loop. Instead I would make the approximation that the loop is small enough that the field from the wire can be considered uniform across the loop. Use the field at a distance L from the wire.
The loop is circular, not rectangular.
Yes. In the orientation shown in the diagram, the angle between the loop magnetic moment (perpendicular to the loop) and the magnetic field is 90 degrees.
