What happens when the coefficient of friction is 0?
When the coefficient of friction (μ) is zero, it implies that there is no resistance to sliding between two surfaces, but this scenario is hypothetical and not practically achievable. The discussion highlights that even with atomically smooth surfaces, electrostatic attraction can create difficulties in sliding due to binding effects. It is emphasized that the coefficient of friction is a property that depends on the interaction between two surfaces, not just one. Additionally, lubricants and other factors can significantly reduce friction, but achieving a true μ of zero is unrealistic. Overall, the conversation clarifies misconceptions about friction and the conditions under which it can be minimized.
GiriBang
My physics teacher said something shocking a few months ago.
During a lecture, he asked what would happen if mu of a solid is zero?
We answered that the solid will slide very smoothly but he said the Electrostatic attraction would make it hard to slide as the distance between the two surfaces has decreased due to absence of irregularities.
This is what he drew.
When I tried to Google this all I get is info about super fluidity.
So is this possible?
I'm not very knowledgeable about this but my first thought was:
how is mu reduced to zero in his scenario?
If it is zero as a consequence of being atomically smooth, then I can see his point,
But is he simply saying it becomes zero by fiat? i.e. by magic? If so, then I think friction would decrease.
He was considering a hypothetical situation.
I think you answered your teacher correctly. When μ = 0, the surface will no longer be able to exert a force parallel to it and in the opposite direction to the velocity of the object sliding on it. That's what would happen within the physical model in which μ scales the force that impedes the horizontal velocity of a sliding object.
Your teacher's response was related not to what would happen, i.e. the horizontal motion is unimpeded, but what physical model could conceivably be the case when the horizontal motion of the sliding object is unimpeded. It is true that if you have two perfectly smooth surfaces of the same material, they will bind and it will be hard to slide one mass on the other. However smoothness is not the only way to reduce μ; lubricants do an excellent job to that effect. Also, a solid does not have a μ. It takes two solids to specify the μ between them.
Likes Merlin3189, Lnewqban and etotheipi
Sorry I forgot to mention the two surfaces or of same material before. Also, is the reason of binding Electrostatic attraction?
GiriBang said:
...he asked what would happen if mu of a solid is zero?...he said the Electrostatic attraction would make it hard to slide...
That makes no sense, since the coefficient of friction tells you how difficult it is to slide, per definition.
If he asked what would happen if the surfaces were perfectly smooth, that's a different story. In vacuum they might even weld together:
https://en.wikipedia.org/wiki/Cold_welding
Likes Adesh, Merlin3189, Lnewqban and 4 others
also search for "jo blocks" or "gauge blocks" -- machinists use them in combination by "wringing" them together.
Likes Lnewqban
Nor am I suggesting otherwise.
A.T.'s post #6 expresses what I was getting at more eloquently.
... but he said the Electrostatic attraction would make it hard to slide...
The coefficient of friction is just a measured rate that quantifies proportion of resistive to normal forces between two surfaces.
Rather than tending to zero, the value of the coefficient that would make the perfectly smooth surfaces hard to slide respect to each other would be high, not only due to electromagnetic effect but due to atmospheric pressure.
Lubrication and magnetism are two tools to reduce the coefficients of friction in bearings and other mechanisms as much as possible.
Note that for practical cold welding, rather than perfectly smooth and flat surfaces, huge amounts of pressing forces are used (hydraulic presses and explosives).
Likes Adesh and GiriBang
So it's wrong to say "coefficient of friction of that surface is x" and right to say "coefficient of friction between those two surface is x" ?
Likes jbriggs444 and Lnewqban
Exactly!
For same smoothness and flatness, surfaces of same material tend to have higher coefficient of friction than different materials.
I believe that fact is related to same molecular alignment of the material.
