What Happens When Using Long-Wave Frequencies with Starlink Antennas?
  • Thread starter Thread starter vutran
    Antenna Array
The discussion revolves around the implications of using long-wave frequencies with Starlink antennas, particularly focusing on the effects on phased-array systems, radiation patterns, and energy conservation principles. Participants explore theoretical and practical aspects of antenna design and performance in this context.
  • One participant suggests that using long-wave frequencies with Starlink's phased-array antennas could lead to a situation where the amplitude gain is N and power gain is N^2, potentially violating energy conservation laws.
  • Another participant clarifies that energy conservation applies over the entire sphere and that the power radiated in a direction is dependent on the amplitude, which cannot exceed unity when considering all directions.
  • Concerns are raised about mutual coupling in closely spaced antenna elements, which may reduce the effective number of elements contributing to gain.
  • A participant questions the assumption that the radiation pattern would be spherical if the wavelength is much larger than the element spacing, suggesting that the amplitude would be uniform in all directions.
  • There is a discussion about the shape of the radiation pattern for Starlink antennas, with one participant noting that they are not omni-directional and have a teardrop-shaped pattern due to their design.
  • Another participant emphasizes the need for accurate analysis of antenna gain, suggesting that mutual coupling effects should be considered in computations and that normalization of power patterns may not be sufficient.
  • It is mentioned that even small arrays can be designed to be unidirectional, but they cannot achieve total isotropy, and the integrated power will still sum to unity.
Participants express differing views on the implications of using long-wave frequencies and the effects of mutual coupling in antenna design. There is no consensus on how to approach the analysis of these effects, indicating ongoing debate and exploration of the topic.
Participants highlight the complexity of antenna behavior at different frequencies and element spacings, as well as the limitations of theoretical models when mutual coupling is present. The discussion reflects a range of assumptions and conditions that may affect the outcomes of analyses.
vutran
It looks very cool.
I have been using phased-array for direction finding & beam-forming, but recently I have come up with an idea that I find difficult to understand.
Let's take the star-link phased array as an example, if we used a long-wave (MHz -- much lower than the one it is designed for), the phase offset among antenna elements would be very small (go to 0) in any direction. Therefore, the amplitude gain in any direction would be N (N: number of elements), and the power gain would be N^2 in any direction which would violate the energy conservation law. Could anyone help me figure out what is wrong here?
Thanks.
Energy conservation applies over the whole sphere. The square of the amplitude gives the power radiated in a particular direction but remember that all the directions where the amplitude is one half, get only one quarter of the power. It can never all add up to greater than unity.
The power beam width is less than the amplitude beam width - is another way of looking at it.
Very closely spaced elements have large mutual coupling that spoils the gain. A way to look at it is that coupling makes many elements behave as one, so you have, effectively, a fraction of N elements.
In this case, I assumed the wavelength is much larger than the element spacing, so the radiation pattern is approximately a sphere, so the amplitude is the same in all directions, isn't it?
But how can I take this into account in analyses in general cases with a spacing of D? Is it correct to compute the pattern regardless of this mutual coupling effect, then normalize it so that ∫(power_pattern) = 1 (or transmission power)?
No, there is no such thing as an omni-directional EM antenna. The Starlink antenna uses microstrip patches on a ground plane so the radiation pattern is confined to a hemisphere. Such elements have maximal amplitude at broadside and fall to zero along the array plane, so the pattern is shaped more like a teardrop.
No. If your antenna has a perfect impedance match, then the gain is approximately $$G=\frac{4\pi A}{\lambda^2}$$where A is the array aperture array. To get an exact value requires analysis with an EM simulation code or measurement in an antenna test range.
Even a very small array can be 'unidirectional', if desired, with deep or slight null(s) in some directions. See this Radio Ham link In any case, as stated earlier, it can't be totally isotropic. As you'd expect, the Power pattern would be narrower (but not all that narrow). The integrated power will still add up to unity.
  • · Replies 44 ·
9K
  • · Replies 37 ·
9K
10K
  • · Replies 16 ·
11K
  • · Replies 69 ·
