Chemistry What ion is Aluminum likely to form?
Aluminum typically forms a +3 ion (Al3+) due to its electron configuration of 1s²2s²2p⁶3s²3p¹, which results in three valence electrons. The confusion arises from using group numbers in the periodic table, which can mislead when applied to certain elements. While technically other ion states like Al+ and Al2+ can exist, Al3+ is the most stable under normal conditions. The stability of ions is influenced by achieving a noble gas electron configuration, which for aluminum corresponds to that of neon. Understanding valence electrons is crucial, as they determine the ionization states an element can exhibit.
forgetful
What ion is aluminum likely to form?
N/A
A self test question from Chemical Principles(Atkins/Jones).
Other than rote memorization I don’t see how to do this. The review section references the Periodic Table and, for elements on the right side of the table, one can use 18 minus the group number which would give Al(superscript 5+) since Al is a group 13; Which is of course wrong. The answer is shown as 3+. What am I missing? Thanks for any help.
What is the electron configuration of Al? How many valence electrons?
Group numbers work only for a "short" periodic table and fail for most d-block and f-block elements.
Electron configuration? I think it’s ##1s^22s^22p^63s^23p^1##
Valence electrons? At first I would have said 1 since there is an incomplete p orbital but reading ahead it seems that it would be all electrons in excess of the nearest noble gas as one moves to the left and that would be 3(and 7 for Cl but that seems high). If what I just wrote is correct would it be true that the number of valence electrons is also the number of ions that a element can have? Thanks for your replies.
Al3+ it is.
For Cl things go in the other direction - the most stable configuration is again the noble gas configuration, but the nearest one is not the one with 7 electrons removed, but the one with an electron added, so Cl-.
Technically ions like Al+, Al2+ (and even Al4+ and so on) are all possible till you strip all electrons and leave just a bare nucleus, but in typical situation (typical for chemistry, which means presence of other substances and temperatures/pressures not much different from these we live in) Al3+ is the most stable one.
Thank you
The Al ion has a +3 charge on it. This is because the Al ion has a neon electron configuration 1s22s22p6. The noble gas neon has a stable electron configuration. All the n=2 orbitals are filled.
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
