Understanding Current Dipoles in Retina Modeling and ERG Analysis
  • Thread starter Thread starter basheersubei
    Current Dipole
Current dipoles in retina modeling and ERG analysis refer to a theoretical concept where charges flow in opposite directions at a point, creating a zero-width current with a finite magnetic moment. This term can be misleading, as it stems from the intersection of different theories of magnetism, which can lead to confusion regarding the fundamental interactions involved. In electrophysiology, the presence of both positive and negative ions flowing in opposite directions contributes to the generation of electric potentials, despite the common understanding that currents primarily create magnetic fields. The discussion highlights the complexity of understanding current dipoles, especially in the context of electric potentials measured at the scalp. Overall, clarity on this topic remains elusive, with a need for more accessible resources to explain the concept effectively.
basheersubei
So I heard the words "current dipole" mentioned in a presentation about modeling the retina and using the ERG (electroretinogram). I understand what an electric dipole means (usually speaking of two point charges with opposite charges). But what exactly is meant by current dipole? All I know is that it is where you have charges flowing in opposite directions at a certain point (?) . I can clearly tell that I don't understand this right.
I've been searching the web for an answer for a while, but I haven't found anything helpful.
I would appreciate it if you point me to an answer (a link to an article that explains it) or give one here.
Thank you for your time.
welcome to pf!
hi basheersubei! welcome to pf! :smile:
basheersubei said:
… I understand what an electric dipole means (usually speaking of two point charges with opposite charges). But what exactly is meant by current dipole?
it seems to be a misleading term for a zero-width current with a finite magnetic moment, see http://en.wikipedia.org/wiki/Magnetoencephalography#The_basis_of_the_MEG_signal
it probably comes from mixing the names of the old and modern theories of magnetic moment, see http://en.wikipedia.org/wiki/Magnetic_moment#Two_definitions_of_moment :wink:
It's certainly used in Radio antenna work.
Here's a useful comment by nicola spaldin, from "magnetic materials: fundamentals and applications", p3 …
Unfortunately, we are going to immediately run into a complication. There are two complementary ways of developing the theory and definitions of magnetism. The "physicist's way" is in terms of circulating currents, and the "engineer's way" is in terms of magnetic poles (such as we find at the ends of a bar magnet). The two developments lead to different views of which interactions are more fundamental, to sightly different-looking equations, and (to really confuse things) to two different sets of units.​
(available free online at
http://books.google.co.uk/books?id=vnrOE8pQUgIC&printsec=frontcover&dq=magnetic+materials&hl=en )
I know this thread is a bit old but I have a question on this topic. In the EEG literature, it is common to discuss scalp electric potentials as arising from current dipoles within the cortex. Firstly, I still don't really get what a current dipole actually is - although I do remember current quadrupoles etc. being mentioned in the multipole expansion for gravitiational waves.
More importantly, I don't see why currents would be the source of electric potentials at the scalp. As far as I was taught electromagnetism, currents cause magnetic fields. It's important to remember that in electrophysiology there are two charge carriers, positive and negative ions, which usually flow in opposite directions in the brain.
No one has any idea about this?
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
