What is Active Curvature Mass?
  • Thread starter Thread starter wacki
    Curvature Mass
wacki
I’ve just read Schutz: “Gravitation from ground up”. He says that there are 4 (not all independent) sources of gravity:
1. density of active gravitational mass = (rho + 3 P)
2. active curvature mass (generating spatial curvature) = (rho - P/c^2)
3. ordinary momentum (gravito-magnetism)
4. Space-time curvature itself -> manifestation in non-linearity of EF
I’m happy with 1. 3. and 4. But don’t know what he means with 2. Does anyone know what this means?
If you answer, please consider that my (all self-taught) level is not above e.g Schutz: “A first course in GR”.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
