What is centre of gravity. How is it calculated?
The center of gravity (CG) and center of mass (CM) are effectively the same in a uniform gravitational field, representing the average location of all mass within an object. The gravitational force between two objects can be calculated using Newton's Law of Universal Gravitation, where the distance is measured between their centers of mass. For example, when calculating the gravitational force between the Earth and the Moon, both are treated as point masses located at their respective centers of mass. This simplification is crucial in elementary mechanics for analyzing translational motion.
  • Understanding of Newton's Law of Universal Gravitation
  • Familiarity with concepts of center of mass and center of gravity
  • Basic knowledge of translational motion in physics
  • Awareness of Quantum Chromodynamics (QCD) for advanced discussions
  • Study the implications of Newton's Law of Universal Gravitation in various systems
  • Explore the differences between center of mass and center of gravity in non-uniform fields
  • Learn about Quantum Chromodynamics (QCD) and its relevance to particle physics
  • Investigate practical applications of center of mass in engineering and mechanics
Students and professionals in physics, engineering, and mechanics, particularly those interested in gravitational effects and particle interactions.
chandran
centre of mass
There is a mass at a position vector r1 from origin. like wise there are different masses at different r from the origin. the
centre of mass is the distance in which the entire mass can be concentrated at some distance R which will give the same EFFECT as that of the original
system.
What is the effect we are talking about?
The "effect" would be related the gravitational force. When using Newton's Law of Universal Gravitation F = G\frac{m_1 m_2}{r_{12}^2} to calculate the force between two objects you calculate the distance between the two objects r_{12} as the distance between the center of masses of the two objects, no matter what shape the two objects posses.
For example, when calculating the gravitational force between the Earth and moon you do the calculation by regarding the entire masses of the Earth and moon as concentrated to two single points located at the center of masses of the Earth and moon. Here the original system is the real Earth-moon system and the "concentrated" system would be considering the Earth and moon as two points with the same masses as the Earth and moon concentrated at the center of mass of the two objects and the "effect" is the gravitational force, ie. it would be the same in both situations. I hope that makes sense.
The center of gravity and center of mass is basically the same thing. Its the average location of all the mass inside an object. You can read more about at http://en.wikipedia.org/wiki/Center_of_mass .
You can simplify matters by assuming that all mass of an object is contained at that point (centre of mass - CM) and you can evaluate the translatory motion of that object considering it as a point particle. This is what you generally do when solving problems in elementary mechanics, such as a car slowing down, a block sliding on a ramp, etc.
The centre of gravity(CG) is the nothing but the CM in a uniform gravitational field.
To Universal & Neutrino. Would your answer also apply to the three quarks found within the proton ? If not, how would one calculate the center of mass for these quarks--or is this even a valid question for a thread on Classical Physics ?
I don't think I'm qualified to answer your question, Rade, :smile:
Rade, your question is a little beyond my knowledge. I believe that quarks are subject to all the fundamental forces, including gravity which means that they have mass. I don't know enough about quarks to know if calculating the center of mass of three quarks is a valid thing to do.
More important than gravity to quark interactions is the strong force (which involves another property called color) which is the major mediating force between quarks. The theory of quark interactions via the strong force is called Quantum Chomodynamics (QCD), and I know next to nothing about this theory. You will probably get a better answer if you asked your question in the quantum forum.
  • · Replies 51 ·
  • · Replies 42 ·
  • · Replies 32 ·
