What Is Gaetan Boucher's Total Acceleration at 1/4 Lap?
  • Thread starter Thread starter Lolagoeslala
    Acceleration
The problem involves calculating the total acceleration of Gaetan Boucher as he skates around a circular track with a radius of 100m, starting from rest and increasing his speed uniformly to complete a lap in 30 seconds. The focus is on determining the acceleration at the point that is one-quarter of the way around the track.
  • Mixed
  • Participants discuss the need to calculate both tangential and radial accelerations, with some suggesting methods to find the speed at the quarter lap point. There are inquiries about angular acceleration and its relation to tangential acceleration.
Participants are exploring various methods to derive the necessary components of acceleration. Some have provided calculations for tangential acceleration, while others are questioning the assumptions made regarding time and angular velocity. There is an ongoing dialogue about the relationship between the tangential and centripetal components of acceleration.
There is confusion regarding the time taken to reach the quarter lap mark, with some participants suggesting that the time may be longer than initially calculated. The discussion includes references to the angular acceleration based on the entire lap rather than just the quarter lap.
Lolagoeslala
Gaetan Boucher started from rest and skated around a circular ice track of radius 100m. He maintained a constant rate of increase of his speed and finished one complete lap in 30s. Calculate the magnitude of his total acceleration as he passed a point 1/4 of the distance around the track from the start.
v1 = 0m/s
r = 100m
d = 1/4d
a = ?
t = 30s
c = 1/4 x 2rπ
c = 157 m
t = 1/4 (30s)
t = 7.5s
157 m = (0m/s + v2)/2 (7.5s)
41.866 m/s = v2
157 m = 1/2a(t)2
5.58 m/s^2 = a
There are two accelerations to be solved for here: tangential and radial.
First get tangential accel: this should be easy from the fact that this accel is constant.
Then you need to solve for speed v at the 1/4 point. You can do that by solving for the time it takes him to go to the 1/4 point (again using the tangential accel.) , then use your value of tangential accel one more time to get v. Finally, you compute the other component of accel (hint: it's called centripetal) to get the total accel.
The total accel is not the numerical sum of the two. The two accels are separate vectors, one pointing tangential to his course and the other towards the center of the ring. If you don't know vectors just leave the answer as two separate accelerations.
Okay i am a bit confused.
you said tangential acceleration,
a = (rw) / t
right?
i have not learned the tangential acceleration thoroughly so.
a = (rw) / t
right?
What is the angular acceleration ?
using this formula ω = θ / t
but i do not know the angle .. not wait i do.
1/4 x 360 = 90 deg
ω = θ / t
ω = n/2 / 7.5s
1/4 x 360 = 90 deg
ω = θ / t
ω = n/2 / 7.5s
That's the average angular velocity for the first 1/4 of a lap.
The skater starts with ωi = 0, & averages π/(2(7.5)) rad/s ?
What is ωf at 1/4 lap ?
(Just as in the case of constant linear velocity, for constant angular velocity, ωAverage = (ωi + ωf)/2 .)
π/(2(7.5)) rad/s = (0 +ωf / 2)
π/7.5 rad/s = ωf
π/7.5 rad/s = ωf
Yes.
From ωf & ωi , you should be able to find the angular acceleration, α .
SammyS said:
Yes.
π/7.5 rad/s = at
π = a
Lolagoeslala said:
π/7.5 rad/s = at
π = a
No. Bad algebra.
t = 7.5 s ,
so a = (π/7.5)/7.5 rad/s2
SammyS said:
No. Bad algebra.
t = 7.5 s ,
a= π/56.25 rad/s^2
Lolagoeslala said:
a= π/56.25 rad/s^2
The tangential component of acceleration is [itex]\ \ a_t=\alpha R\ .[/itex]
The radial component of acceleration is simply the centripetal acceleration.
like this?
π/56.25 rad/s^2 x 100 m = a
5.58 radm/s^2 = a
Lolagoeslala said:
like this?
5.58 radm/s^2 = a
That's only the tangential component.
a = 5.58 radm/m^s2
d = 200 m
C = 200 m x 3.14
C = 628 m
D = 1/4 628 m = 157 m
157 m = 1/2 (5.58 radm/m^s2)(t)^2
t = 7.5 s
157 m x 2 / 7.5 s =v2
41.866 m/s = v2
a = 41.866 m/s /100m
a = 0.041866 m/s^2
Lolagoeslala said:
a = 5.58 radm/m^s2
d = 200 m
C = 200 m x 3.14
C = 628 m
t = 7.5 s
41.866 m/s = v2
a = 0.041866 m/s^2
You went through some needless steps there.
You already have ω at t = 7.5s, which you already know is the time at the 1/4 lap mark.
v = ωR .
Centripetal acceleration is ac = v2/R .
(It's also equal to 2R)
I get a value different from yours.
By the way, rad∙m/s2 is merely m/s2 .
v = ωR .
41.866 m/s = v2
a = v^2 / R
a = 41.866 m/s^2 / 100m
a = 17.52 m/s^2
41.866 m/s = v2
a = v^2 / R
a = 17.52 m/s^2
That's about right.
Tangential acceleration is in the direction of motion. Centripetal acceleration is towards the center of the circle. Therefore, they're perpendicular to each other.
Find the magnitude of the acceleration using your two results.
a = 17.52 m/s^2[W] + 5.58 m/s^2
like this?
like this?
No.
Acceleration is a vector quantity.
Tangential component is perpendicular to radial.
SammyS said:
No.
i am bit confused i have not worked with tangential component before
In earlier posts this was mentioned, particularly in post #12.
Consider an object moving along some path. The velocity vector for the object will be along a line tangent to the path. The component of acceleration in the direction of the velocity vector is given by the time rate of change of the speed of the object: [itex]\displaystyle \frac{dv}{dt}\,,\ \ \text{ where }\ v=|\vec{v}|\ .[/itex]
At any rate, the tangential component is perpendicular to radial, so use the Pythagorean theorem to find the magnitude.
c^2 = (17.52 m/s^2) ^2 + (5.58 m/s^2 )^2
c = 18.38 m/s^2
c = 18.38 m/s^2
That's correct to 3 sig. fig.
so that's the answer
i do not need to worry about the orientation?
but the answer does not match up with the answers possible.
What are the possible answers ?
1.4 , 2.99 , 4.39 , 4.60 , and 5.78
Oh ! I see what went wrong.
It takes longer than 7.5 s for the first 1/4 of a lap.
Base the angular acceleration on one complete lap.
ωf = 2ωavg = 2(2π)/30 .
Angular acceleration, α = (ωf-0)/30 . That's 1/4 of the former answer.
i am abit confused
  • · Replies 38 ·
  • · Replies 30 ·
