How Does Intrinsic Derivative Differ from Covariant Derivative in Geometry?
  • Thread starter Thread starter off-diagonal
    Derivative
off-diagonal
What is it? and How different between intrinsic(absolute) derivative and covariant derivative?
What is its geometric interpretation?
If on a manifold you have two vector fields V and W, then you can take the covariant derivative of V wrt W at every point in the manifold. The vector field W can also be thought of as a family of curves whose tangent vectors form W. The absolute derivative of V at any point on a particular curve in that family is the covariant derivative of V wrt W at that point in the curve.
The geometric idea is that in a vector space, there is an idea of two vectors being parallel. But on a manifold, there is a vector space at each point in the manifold, but there is no predefined notion of vectors at different points on a manifold being parallel. The covariant derivative/absolute derivative defines the notion of "parallel transport" that allows you to say if vectors at two nearby points on a curve are parallel or not.
I checked the definition on p377 of http://books.google.com/books?id=vQ...D+physics+geometry+liek&source=gbs_navlinks_s.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
