Understanding Momentum: Definition, Intuition, and Properties
  • Thread starter annie122
  • Tags
    Momentum
In summary, the conversation discusses the concept of momentum and its relation to mass and velocity. Some ways to think of momentum include "the quantity of motion" of an object, "mass in motion," and how hard an object hits. The conversation also touches on the relationship between momentum and kinetic energy, and the use of natural units in physics. Overall, the conversation highlights the importance of understanding the distinct quantities of momentum and energy.
annie122
51
I know momentum is mass times velocity, and that it is a conserved quantity, but I can't get the intuition of what momentum is, unlike mass and velocity.
Mass relates to how heavy an object is, and velocity is how fast an object is moving.
One idea I had is that momentum is how hard an object hits me, but I'm not entirely sure if that's an okay thing to say.
Yeah, momentum is how hard something hits you ... that's not a bad way to think of it.
If it's moving faster, it hits you harder. If it's heavier, it hits you harder. If it's both heavier and faster, you really should get out of the way.
You could also think of it as "the quantity of motion" of an object.
The easiest way for me to think of it is "mass in motion." Momentum is just how much "mass in motion."
Momentum can also be thought of as Kinetic energy.
KE = p2/2m
p = SQRT(2m*KE)
The higher the KE, the higher the momentum.
True, for two objects of the same mass.
Neandethal00 said:
Momentum can also be thought of as Kinetic energy..
Not true.
Well they each have the same unit... the eV :p
Not sure what you mean.The eV is a unit of energy,not momentum.
momentum p is indeed mass m x velocity v
p = mv
mass... is not actually the weight... weight is mass x gravity... so mass of something is its weight then deduct any gravity it was weighed in ie earth, moon etc
velocity... though is not actually speed... it is a speed and a direction... 50mph east
Kinetic energy scales at 1/2 mv^2. When you double your speed you quandruple your kinetic energy. This does not happen with momentum. It scales linearly at p=mv.
If 2 objects made of the same material have the same momentum, but different KE, the little one will be harder to stop. If they both have the same KE but different momentum, the big one will be harder to stop.
? Momentum has the Unit Ns (Newton seconds) but KE has the unit J (Joules). Not the same at all.
Momentum is a Vector quantity - it has a direction associated with it. KE has no direction specified because it is a Scalar, not a Vector.
Momentum is conserved in all collisions. Kinetic Energy is not.
But, as an object speeds up, both its momentum and KE increase - so there is a kind of association between them.
That article claims that "in high energy Physics, electron-volt is often used as a unit of momentum". I really doubt that, unless they are talking in some very isolated context. It sounds so wrong that I can't take that sentence seriously. Wiki can often be wrong and, more often, be written badly or with insufficient editing.
Whatever the article says, it is important to realize that they are two distinct quantities. I can't think anyone would claim otherwise.
I had the same reaction when I first read it but then the paragraph goes on to describe that momentum can be described by eV/c.I'm guessing that if there are people who use the eV as a unit of momentum then it is implied(though not stated) that c is included as above.If so it seems a bit sloppy to me.
Sloppy, yes. But you get this sort of thing with terminology within specialised fields. Very confusing for the outsider. (Perhaps that's why it's used?)
We used natural units in just about every physics class we had. Its pretty common.
"Natural", meaning what?
The system of natural units.
http://en.wikipedia.org/wiki/Natural_units
?? I am not sure where the confusion lies. Have you really not heard of natural units before? Your professors are doing you a disservice!
Good King Hal established the only system of Natural Units of any importance and the Americans, God bless their cotton socks, are still using some of them.
HAHA. My professors are nearly all dead by now, I reckon.
I still think that a system of units which draws no distinction between Momentum and Energy is asking for trouble.
But I can't find a reference to Momentum in that link. The link itself seems to make good sense. Is there some confusion somewhere in this thread, perhaps?
There is a distinction, but they are also intimately related. Both energy and momentum are the constituents of the 4-momentum. You boost between the two and turn your energy into momentum and back. In this sense, I think you can think of momentum as energy (or vise versa).
What does "boost" mean, please?
I think modus is referring to the four vector pμ for a relativistic particle formed from its three spatial momenta and its energy divided by c.
pμ = the four vector {px, py, pz, iE/c}
The scalar product pμpμ is invariant
pμpμ = p2x + p2y+ p2z - E2/c2
= -m02c2 = a constant
I have yet to see anything to tell me that momentum and energy are the same, though. I know that mass and energy are equivalent but are they also both equivalent to momentum? I don't think so.
I didn't say they were the same.
The equation I quoted leads to another
E2 - p2c2 = m02c4
This doesn't say you can trade momentum for energy directly but tells us that a change of mass must also be involved to achieve this.
Incidentally, (someone correct me if this is wrong) I think a boost is the spacetime 4vector analog of acceleration ie what you obtain if you (vector) differentiate 4velocity. This differentiation is a linear transformation.
Boosting is when you change your inertial frame, when you do a lorentz transformation.
You get into your rocket and turn on the engines, you mean?
That requires energy, surely, which nullifies any implied equation between momentum and kinetic energy.
I got into this thread in response to a bald statement that the two are "the same". If a statement like that is left unchallenged then all sorts of people will go away with the wrong idea. I really can't see the point in posts (from several different people) which just play with words an dissemble about the topic. Some of the points are interesting, of course, and take us into more advanced Physics but I think it is only fair, when making them, to point out their context and that they don't mean that, in a car crash or a game of snooker, momentum and KE are the same.
I have done my share of 'showing off', I know, but it is helpful, when airing some extra knowledge, if people put the new stuff in context and don't imply that 'old' Physics got it wrong - which is what has been happening on this thread.
Is it correct to say that momentum is of no use unless we are talking about collisions of a sort?
Can momentum have any useful applications in a system where objects/particles move but are not liable to collide/interact at all? Need it be defined in the first place in such a system?
IH
Islam Hassan;3739114 Can momentum have any useful applications in a system where objects/particles move but are not liable to collide/interact at all? Need it be defined in the first place in such a system? IH[/QUOTE said:
Can you think of an example of such a system and how it could be of interest in Physics?
  • #31
Yes of course, the interaction of a particle (or stream of them) and a field changes the momentum of the particle(s).
There is a simple secondary school experiment which discusses this in terms of the interaction of alpha, beta and gamma rays with a magnetic field.
Do you know this?
  • #32
Are you suggesting that momentum is not exchanged or changed then under those circumstances? Is that not where the idea of photon interaction comes in? Alpha particle moves to the right - magnet moves to the left. If not then we have reactionless propulsion. (And you could carry your own magnetic field with you yet still get a force)
  • #33
Again I said no such thing.
Indeed quite the opposite.
However Hassan specifically asked about the situation where the particles
A single or stream of positive or negative particles passing through a magnetic or electric field do not collide or interact with other particles.
They interact with the field (which can have no momentum of its own) however.
Which is what I said.
  • #34
So where does the momentum come from? If the particle's motion is changed then there has to be some. The concept of a Field is an artifice, because all fields are there because of the presence of some particle(/s) somewhere -just like the Earth is there for a bouncing ball but we 'ignore it'. In all cases there is a change in momentum which may be regarded as being magicked away (not very satisfactory). But if you regard the change in direction as being due to a photon interaction you're back in business. The deviated particle will have launched its own photon i.e. perturbed the Field.
  • #35
Boost is a Special Relativity term. It just means changing observer's point of view from one coordinate system to another, moving at a constant speed relative to the first one. It is a fancy kind of rotation of 4D space-time coordinate system in X-T plane. During the boost, spatial and time coordinates get mixed up a little, just like X and Y get mixed up when rotating in XY plane.
They are indeed the same but in different dimensions :)
Four-momentum 4-vector can be loosely interpreted as a "rate of flow of mass through 4D space-time" with respect to its own "proper time". Thus momentum (p1,p2,p3) becomes a flow of mass through space and the energy term p0 is a "flow of mass through time". Kinetic energy turns out to be Lorentz factor correction to the total relativistic energy in the limit v<<c.
PS: Relativistic Caveat: This is relativistic treatment of momentum. There is no such obvious connection between momentum and KE in Newtonian physics.
  • Mechanics
