What is the formal definition of reactivity and how can it be quantified?
  • Thread starter Murtuza Tipu
In summary, the concept of a reactive species can be understood as one that has a high potential for participating in reactions. However, reactivity is not necessarily equivalent to energy and there is no formal theory or quantitative definition for it. The concept is often used to describe species with unpaired electrons, but this does not fully explain their reactivity. It is possible to measure reactivity empirically, but it is difficult to compare and quantify it as it can vary depending on the environment and conditions. Understanding reactivity requires knowledge of Molecular orbital theory and reaction kinetics.
Murtuza Tipu
49
I understand the concept of a reactive species on a sort of vague and intuitive level: a reactive species is one that has lots of reactions that it can participate in. These tend to have large kinetic constants, be thermodynamically downhill and often have products that are also reactive, leading to knock-on effects. But reactivity isn't the same as energy, and it's possible to have highly reactive species with relatively low free energies and vice versa.
I'm interested in whether there's any kind of formal theory of reactivity, and/or a quantitative definition of the concept. For example, we're often told that free radicals are reactive because they have an unpaired electron and they "want" to fill their outer shell. This makes perfect sense on an intuitive level, but I'd like to know if it can be taken further. Is there some way we can write down an equation that will tell us how reactive a species will be in a given environment, or is there some way we can measure a species' reactivity empirically and use it to make predictions?
In particular, what does it really mean to say that one species is more or less reactive than another? Can we put a number to it and say that a species has a reactivity of 8.2 on some meaningful scale?
thanks.
Chemistry news on Phys.org
To understand reactivity you pretty much need to look at Molecular orbital theory.
In a nutshell, the free electrons "want" to bond as by bonding they fall in a lower energy state. If the bond results in a higher energy state they will not "want" to bond and the bond will be unstable, as the direction is from higher to lower energy states.
Intuition does not help much here, you will need to understand the theory and then there are computer programs that help, as the math is an eyesore.
For a reactive species to be more or less reactive, that does not mean anything really. It is not a term for comparison as by modifying the conditions you can easily get mixed results. A reactive species could react violently to something and be mostly inert to others. A simple example is Na+H2O and Na+alkane, where Sodium's reactivity with water does not mean anything for alkanes which do react with other species.
https://www.youtube.com/watch?v=5CgLh9_f5ns&list=PL50CC04CE699FF4B3
I do make too much advertising to these courses, but they are quite good for beginners (like me).
What is reactivity and why is it important in science?
Reactivity refers to the tendency of a substance or element to undergo a chemical reaction with other substances. In science, it is important because it allows us to understand and predict how substances will interact with each other, which is crucial in fields such as chemistry and biology.
How is reactivity measured?
Reactivity can be measured in various ways, depending on the specific context. In general, it is measured by observing the rate at which a substance reacts with other substances, or by measuring the amount of product formed in a chemical reaction.
What factors affect reactivity?
The reactivity of a substance can be affected by several factors, including its chemical structure, temperature, and the presence of catalysts or inhibitors. These factors can either increase or decrease the reactivity of a substance.
What are some examples of highly reactive substances?
Highly reactive substances are those that readily undergo chemical reactions with other substances. Some examples include alkali metals such as sodium and potassium, which are highly reactive with water, and halogens such as fluorine and chlorine, which are highly reactive with metals.
How can reactivity be controlled?
Reactivity can be controlled by adjusting the conditions in which a substance is exposed to other substances. For example, the addition of a catalyst can increase the reactivity of a substance, while the use of inhibitors can decrease reactivity. Additionally, controlling temperature and concentration can also affect reactivity.
  • STEM Academic Advising
  • Linear and Abstract Algebra
  • Mechanical Engineering
