What is St. Elmo's fire enrgy source?
  • Thread starter Thread starter Stanley514
    Fire Source
St. Elmo's fire is a phenomenon that produces light through electrostatic energy, which ultimately originates from the Sun. The discussion highlights that while a current is typically needed for useful energy, light can be generated from a strong electric field without a current flowing. Some participants argue that this light could potentially be converted into electricity using photocells, although the amount of energy generated would be minimal. The source of the energy is linked to thunderstorm activity, specifically the friction that moves electrons. Overall, the conversation emphasizes the distinction between light generation and the ability to harness useful energy from it.
Stanley514
Simon Bridge said:
It's electrostatic ... ultimately from the Sun.
http://science.howstuffworks.com/nature/climate-weather/atmospheric/st-elmo-fire1.htm
The passage in wikipedia you quoted actually tells you where the energy comes from...
I thought that in order to obtain useful energy, a current should flow. Yet, according to their description all this phenomenon happens before conditions for lightning are completely created. In my opinion a simple static field cannot generate an energy to do a work...
Where are you getting the idea that this can generate "useful" energy/work? Or that it happens before there is a significant charge separation?
That's not right - you can get light without any current flowing if you can just move enough charged particles around enough. The electrical field is quite strong enough to separate electrons from their parent atoms leaving us with a mixture of negative-charged electrons and positive-charged ionized atoms. Thermal motion in tis sea of charged particles then generates light.
Stanley514 said:
flow.
Basically? Your thought on this matter is mistaken.
Unfortunately Nature does not care about opinions, yours or mine.
Have you never seen a demonstration where a florescent light glows in an electric field, with no current passing through it?
http://techtv.mit.edu/collections/p...uorescent-and-neon-tubes-in-an-electric-field
Well, if there is a lights, we could convert this light into electricity with help of photocell and make it some useful work to do.
Sure, but very, very little. I'm not sure it could generate enough to call it "useful". Still, again, this doesn't imply a conservation of energy issue. I'm not seeing a problem here.
Even amount of energy sufficient to power a pocket calculator is useful. I wanted to know when it came from. Is there a changes in electric field?
Likes russ_watters
Your article alludes to the source being the thunderstorm, but more specifically it is friction stripping and moving electrons around. Similar to when you shuffle your feet on a carpet:
http://scijinks.jpl.nasa.gov/lightning/
