What is the true nature of temperature in physics?
  • Thread starter Thread starter rogerk8
    Temperature
Temperature is fundamentally a measure of atomic vibration and particle speed, influencing heat transfer between objects. The discussion explores the relationship between temperature, entropy, and internal energy, highlighting the need for accurate calculations using the Stefan-Boltzmann Law. Initial calculations of the sun's temperature were incorrect due to unit discrepancies, but after applying the correct law, a revised estimate of 4391K was achieved, which is closer to the actual surface temperature of 5800K. The conversation emphasizes the importance of understanding temperature in the context of heat flow and entropy maximization. Overall, the nature of temperature is tied to energy distribution and thermodynamic principles.
rogerk8
Hi!
I wonder what temperature really is.
I have learned that temperature comes from the fact that atoms vibrate.
But in plasma physics it can be related to the actual speed of particles.
So what is temperature?
It was interesting and educational to read the new thread regarding heat capacity but I think my question requires a new thread.
By the way, is there anything wrong with the following calculation of the sun's temperature (considering the sun's radiation being isotropic):
I_s=\frac{P}{S_s}=\frac{P}{4\pi R_s^2}=k*T_s
I_e=\frac{P}{4\pi (AU)^2}=k*T_e
T_s=T_e*\frac{I_s}{I_e}=T_e*(\frac{AU}{R_s})^2=300*(\frac{1,5*10^{11}}{700*10^6})^2=14MK
I really am not sure what I have calculated but wikipedia says that the sun core temperature is some 16MK. Which is pretty close even though I was aiming at the sun's surface temperature...
Roger
Science news on Phys.org
Conceptually, Temperature is a measure of the tendency to donate heat. When to objects come in contact, the one with higher temperature will donate heat to the one with lower temperature
A relation between entropy and internal energy:
$$\frac 1 T = \left(\frac {\partial S} {\partial E}\right)_{V,N}$$
You should have used the Stefan-Boltzmann law. What are you using here? The units aren't even correct with your equation. The left-hand side has units of mass/time3, the right of energy (mass*length2/time2). Always check your units.
$$\frac 1 T = \left(\frac {\partial S} {\partial E}\right)_{V,N}$$You should have used the Stefan-Boltzmann law. What are you using here? The units aren't even correct with your equation. The left-hand side has units of mass/time3, the right of energy (mass*length2/time2). Always check your units.
Hi D H!
Thank you for your input!
Let's recalculate now that I have studied the Stefan-Boltzmann Law:
I_s=\frac{P}{S_s}=\frac{P}{4\pi R_s^2}=k*T_s^4
I_e=\frac{P}{4\pi (AU)^2}=k*T_e^4
T_s=T_e*(\frac{I_s}{I_e})^{1/4}=T_e*(\frac{AU}{R_s})^{1/2}=300*(\frac{1,5*10^{11}}{700*10^6})^{1/2}=4391K
Which isn't so far from 5800K.
Roger
PS
Your entropy formula didn't say me much but now I at least have some words to google.
By the way, P stands for power which I have stolen from acoustics.
Temperature tells you which direction heat will travel. For positive temperatures, heat will travel from a higher temperature to a lower temperature. The end result is an increase in entropy. This will continue until temperatures are equal, at which point the entropy is at a maximum.
  • · Replies 16 ·
