What is the approach for finding fringes on a screen with three slits?
  • Thread starter Thread starter radonballoon
    Interference Slit
The discussion revolves around a physics problem involving three slits and the resulting interference pattern on a screen positioned at a significant distance from the slits. Participants are exploring the periodicity of the fringes created by this setup.
  • Participants are considering how to extend the two-slit interference concept to three slits, questioning whether to calculate phase differences between pairs of slits and how to combine those differences. There is also confusion about the correct approach to determine the overall phase difference.
The discussion is active, with participants sharing their thoughts on the relationship between the three slits and the interference patterns. Some guidance has been provided regarding the similarity to two-slit patterns, but there is no explicit consensus on the method to be used for calculating the phase differences.
Participants are working under the constraints of a homework assignment, which may limit the information they can access or the methods they can use to solve the problem.
radonballoon
There are three slits in a screen, with one aligned with the source at z=0, one a distance a above 0, and one a distance b below 0. Another screen is at a distance d >> a,b from the first. What is the periodicity of fringes on the screen?
[tex]\Delta \phi = \frac{2\pi}{\lambda}(x_1-x_2)[/tex]
I know for two slits that you subtract the distances from the slits to the screen and multiply by the wave vector to get the difference in their phases, and when that difference is a multiple of pi that the intensity is minimum. My question is what do you do for three slits? Subtract two and then subtract the third from that? I'm confused as to how to approach this problem. Any help would be appreciated.
Well, you know what the pattern from TWO slits looks like, so you're most of the way there. Three slits is the same thing as three pairs of slits, three double-slit patterns superposed on each other. The rest is just some moderately complicated algebra.
So then would I be on the right track if I found the phase difference between each pair and then added them to get the final phase difference?
Sounds right to me :)
  • · Replies 28 ·
  • · Replies 33 ·
