What is the coefficient of kinetic friction for the incline?
The coefficient of kinetic friction for a block sliding down a 23-degree incline was calculated to be approximately 0.4526. The block, with a mass of 7 kg, accelerates at 0.2535 m/s². The net force equation was established as Fx = Ff - mg sin(23º), where Ff is the frictional force. Proper attention to the signs in the force equations is crucial for accurate calculations.
  • Understanding of Newton's second law of motion
  • Knowledge of forces acting on an inclined plane
  • Familiarity with trigonometric functions in physics
  • Ability to manipulate equations involving friction
  • Review the derivation of forces on inclined planes
  • Learn about the role of friction in motion dynamics
  • Explore the concept of static vs. kinetic friction
  • Study the effects of angle of incline on acceleration and friction
This discussion is beneficial for physics students, educators, and anyone studying mechanics, particularly those focusing on forces and motion on inclined planes.
DrunkApple
A block(7 kg) is released from rest on an inclined plane of 23 degrees and moves 2.8 m during the next 4.7 s. The acceleration of gravity is 9.8 m/s^2. What is the magnitude of the acceleration of the block? What is the coefficient of kinetic friction for the incline?
I already calculated the acceleration of the block which is 0.2535 m/s^2.
Fn=mgcos23=63.14663295
Fx=ma=Ff-mgsin 23
7(0.2535) = 63.14663295 * (coefficient) - 26.80415541
coefficient = 0.452576077
Can you check my calculation please?
DrunkApple said:
A block is released from rest on an inclined plane of 23 degrees and moves 2.8 m during the next 4.7 s. The acceleration of gravity is 9.8 m/s^2. What is the magnitude of the acceleration of the block? What is the coefficient of kinetic friction for the incline?I already calculated the acceleration of the block which is 0.2535 m/s^2.
I'm assuming that somewhere you were given a mass for the block of 7 kg., which is not mentioned in the problem statement above. However, you could ignore it entirely, since you only want to work with the acceleration along the incline, so you can divide out m early on. Anyway...
Fx=ma=Ff-mgsin 23
7(0.2535) = 63.14663295 - 26.80415541(coefficient)
You've attached the coefficient of kinetic friction to the wrong term in the second line: Ff should be \mu \cdot mg \cos 23º.
One other thing: as you've written the equation for the net force along the incline, the left-hand side is "positive downhill", but the right-hand side is "positive uphill", since you've made the friction force positive and the "downhill" component of the weight force negative.
ok i fixed everything. Could you check it please? My online homework keeps say it is wrong
Not quite: are you calling "uphill" or "downhill" the positive direction? The signs on the two sides of your force equation still aren't following the same choice. (With the block sliding downhill, which way does the friction force act?)
uphill is the positive direction
Then, since the block is sliding downhill, its net acceleration is negative. You need to change the sign of the left-hand side of your equation now.
hmmm... negative... then acceleration is for x-component no?
What you have written,
F_{x} = ma = F_{f} - mg \sin (23º) ,
indicates that you are placing the x-axis parallel to the slope of the inclined plane already. That puts the "normal direction", which is perpendicular to the inclined plane, parallel to the y-axis, which is why you can write
F_{n} = mg \cos (23º) .
So the friction force is F_{f} = \mu \cdot F_{n} = \mu \cdot mg \cos (23º) . The order in which you wrote the forces for Fx indicates that you have already chosen "uphill" along the incline to be positive. But the block is going to slide "downhill", so ax will be negative. (ay is zero, since the block will not accelerate perpendicularly to the inclined plane; in fact, this was used to come up with Fn - mg cos (23º) = 0 , the second term being the component of the block's weight in the normal direction.
So, yes, your equation should read
ma_{x} = F_{f} - mg \sin (23º) ,
with ax < 0 .
You have to be careful, once you have chosen the directions for the coordinate axes, to be consistent with them in giving the signs to forces, accelerations, velocities, etc. Placing the wrong sign on a term will change the meaning of the force equation and lead to an incorrect solution. (The exception is if all the signs in the entire equation are reversed: this corresponds to pointing that coordinate axis in the opposite direction and will change the sign of the solution, but not the meaning. That is, if positive-x points "downhill" and the acceleration ax is positive, then the object is accelerating downhill; if positive-x points "uphill", then ax will come out negative, but that still representing downhill acceleration.)
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 33 ·
