What is the condition of true weightlessness?
True weightlessness occurs only when an object is not subjected to any gravitational force, specifically when gravitational acceleration (g) equals zero. This condition can theoretically exist far from any astronomical bodies, such as in deep space. In contrast, apparent weightlessness, often experienced by astronauts in the International Space Station (ISS), results from being in free fall, where the effects of gravity are still present but counteracted by the motion of the spacecraft. The distinction between true and apparent weightlessness is crucial for understanding gravitational effects in different contexts.
  • Understanding of gravitational forces and their effects
  • Familiarity with the concepts of free fall and orbital mechanics
  • Basic knowledge of Newtonian physics, particularly the equation F=ma
  • Awareness of the differences between mass and weight
  • Research the concept of gravitational force and its reach in physics
  • Study the principles of orbital mechanics and how they relate to weightlessness
  • Explore the differences between true weightlessness and apparent weightlessness in various contexts
  • Investigate Lagrange points and their significance in gravitational interactions
Physics students, educators, and anyone interested in the principles of gravity and weightlessness, particularly in the context of space travel and astronautics.
shk
I think only happens when gravity is zero.
But as gravity of Earth won't be zero , we need to be somewhere between Earth and Moon so the g of moon and Earth cancel each other out . At this point we will have true weightlessness. Is this correct and enough?
Well, do you think that the other planets and the sun have no effect in that position? Note I didn't ask if you think they have a SMALL effect, but if they have ANY effect.
On the other hand, think about astronauts in the ISS. Do you think they are not weightless?
What is the difference between "weightless" and "in free fall" ? Where does "in free fall" occur?
If you have a distribution of mass, you may find a point where g = 0 through simple math. The question is do you have a distribution of mass? Probably not.
i understand but
Do you know what is the condition of weightlessness?
shk said:
i understand but
You didn't answer my questions.
I am a bit confused with this website. I have been trying to get the answer for my question but everyone is asking me a question instead of answering my question.
I would appreciate it if you can answer my question as it saves a lot of time for me. all i want to know is:
what is the condition of true weightlessness?
The condition of weightlessness is usually that a device which measures weight (a scale) read 0.
thanks but I think this the condition of apparent weightlessness!
Then please provide a scientific reference that explains this concept of “apparent weightlessness”. It is a term I have not seen.
1.True weightlessness
It occurs only when an object is not subjected to any gravitational force .For example , if the astronaut is very far from the Earth and other astronomical objects, then g = 0, and there is true weightlessness.
2.Apparent weightlessness
For the spacecraft , there are two special examples of apparent weightlessness.
The first is the obvious case of the spacecraft falling vertically downwards with acceleration g.
The second is the case of the spacecraft circling the Earth. Although the motion is along the circle , the acceleration is still downward and equal to g , provided that there are no other forces such as air resistance or engine thrust .but I am still not sure about the true weightlessness as I am not sure if such a place exists
This appears to be your own personal definition, not one from an authoritative source.
Yes, exactly. That's because our goal is to help people find answers for themselves, not just spoon feed answers. This is not a "Q&A" type forum where you just ask a question and get an answer.
I found it here:
http://www.skhlkmss.edu.hk/physics/Gravitation/weightlessness.htm
I have been googling this the whole day to see what true weightlessness really is. Someone asked me this yesterday and i am looking every where to find the answer. he said this is part of his A level homework.
It seem that apparent and true wheightlessness are 2 different things
probably I'm in a wrong place then . I just need the answer so I can help someone with physics. I am a Maths teacher but I occasionally help my students with physics
Ok, I have never heard of it before, but you have the definition and it seems pretty clear. According to this source true weightlessness is when g=0.
Dale said:
Ok, I have never heard of it before, but you have the definition and it seems pretty clear. According to this soybe I rce true weightlessness is when g=0.
ok thanks
maybe I should accept this although I am not sure if in reality such a place exists.
I understand your definition of weightlessness but "True weightlessness" seems to be something different.
Thanks
Weight has nothing to do with gravity.
Weight is a phenomenon of a contact force. If you're sitting on a hillside, the component of the normal force that is pushing your arse straight up is what causes "weight".
If you're in a rocket traveling through space, no matter how many planets and moons you swing by you will remain weightless until you actually contact a planet (or its atmosphere) or fire up the engine (or maneuvering thruster).
I also don’t think such a place exists, which is probably why most sources don’t bother with such a definition. I would prefer just to use the standard easily measurable definition.
I understand
Many thanks for your time. It helped a lot.,
so how would you differ true weightlessness and apparent weightlessness?
I wouldn't use those terms, which seem to be a second order misunderstanding of the principles involved. The first order misunderstanding is the misleading expression "zero gravity", referring to satellites in free-fall.It's not exactly simple : people are still arguing whether gravity is an actual "force" or not.
Your link defines "true" weightlessness as "It occurs only when an object is not subjected to any gravitational force". Given that the reach of the force of gravity is infinite, there IS no such place, so I think this "distinction" is as meaningless as that definition.
EDIT: Note, I'm using "force" in the Newtonian sense, but my point is still valid under GR
I wouldn't use either term. I would just use 'weightlessness', and I would define it as the absence of a normal force derived from gravitation.
Sounds like he's being asked to calculate the location of one of the moon's LaGrange points, L1 IIRC
I wonder here if the OP may be asking, in so many words, if the object in a position of zero gravity still has mass? ## \\ ## I didn't read all of the posts yet, but what might be an item of interest for the OP: ## \\ ## If you are on Earth and someone throws a baseball at you at 60 m.p.h., it hits your baseball mitt with a pretty good force. If you are on a spaceship and playing catch with a baseball and someone throws it at you at 60 m.p.h. , you will feel the same force when you catch it that you did on earth. The object still has mass, and the equation ## F=ma ## still applies. ## \\ ## In zero gravity, the downward gravitational force ## F_g=mg ## is absent, so that there is no downward acceleration of ## g ## of any objects. Just because they are weightless does not mean that their mass has disappeared. That mass ## m ## is still present.
good point. I'm not 100 percent sure what are Lagrange points. But I suppose they are where the values of g's of Moon and Earth cancel each other out so the Net force becomes zero . Not sure how I can relate this to weighlessness though
so you're saying that when g is zero weight is zero. correct ?
OP : of what use is dividing the term "weightless" into "real" and "apparent" ?
EDIT: Okay, "apparent weightlessness" is microgravity. So, that would make "real weightlessness" . . . what ?
I have just seen the term true weightlessness in an A2 physics question. then I started googling it and found out that we have true and apparent weightlessness. So I started to think that these are 2 different things
Was the term "true" relevant contextually to the question ?
  • · Replies 55 ·
  • · Replies 19 ·
9K
