What is the derivation of the second equation for area velocity?
  • Thread starter Thread starter Shreya
    Formula Velocity
The discussion revolves around the derivation of equations related to area velocity in the context of motion in a plane, specifically focusing on the second equation. Participants explore the relationship between position and velocity vectors and their implications for area swept out over time.
  • Participants discuss the derivation of the first equation for area velocity and express uncertainty regarding the second equation. There are attempts to relate the area swept out to vector cross products and to use polar coordinates for calculations. Questions arise about the correctness of specific expressions and the reasoning behind them.
Some participants have provided insights into the derivation process, particularly for the first equation, while others are seeking clarification on the second equation. There is a mix of approaches being explored, with some guidance offered on using vector relationships and coordinate transformations.
Participants are working within the constraints of deriving equations based on given formulas and are questioning the assumptions related to motion in a plane. There is an emphasis on ensuring the correctness of mathematical expressions without reaching definitive conclusions.
Shreya
I want to understand the second equation for Areal velocity as given below.
Refer below.
I think I understand how the first equation comes about.
In ##dt## the particle travels by ##dr##, I considered it as a triangle with altitude ##r## and base ##dr##. On dividing the area travelled in ##dt## by ##dt## we get the above equation.
A similar argument can be applied to ##\frac 1 2 \rho^2 \frac {d\phi} {dt}## as ##\rho## is same as r and ##\rho \frac {d\phi} {dt}## is same as ##\frac {dr} {dt}##
But, I am not able to understand the 2nd equation. I can provide a similar argument for ##xv_y## but can,t seem to reason any further.
Please be kind to help.
The unsigned area swept out in time [itex]\delta t[/itex] is approximately [tex]|\delta S| \approx \tfrac12 <br /> \|\mathbf{r} \times (\mathbf{r} + \mathbf{v}\delta t)\| = <br /> \tfrac12 \|\mathbf{r} \times \mathbf{v}\| |\delta t|.[/tex] This is because the magnitude of the cross-product gives the area of the parallelogram bounded by [itex]\mathbf{r}[/itex] and [itex]\mathbf{r} + \mathbf{v} \delta t[/itex], and the area swept out is approximately the area of a triangle which is one half of the parallelogram. Dividing by [itex]\delta t[/itex] and taking the limit [itex]\delta t \to 0[/itex] gives [tex] \left|\frac{dS}{dt}\right| = \tfrac12 \|\mathbf{r} \times \mathbf{v}\|.[/tex] This is essentially the derivation of the first formula.
To derive the second, in the case of motion in the [itex](x,y,0)[/itex] plane we can calculate [itex]\frac12\|\mathbf{r} \times \mathbf{v}\|[/itex] either in cartesians or in plane polars using the standard formulae [tex]\begin{split}<br /> \mathbf{r} &= r\mathbf{e}_r(\theta) \\<br /> \mathbf{v} &= \dot r \mathbf{e}_r(\theta) + r\dot \theta \mathbf{e}_{\theta}(\theta) \end{split}[/tex] where [tex] \mathbf{e}_r(\theta) \times \mathbf{e}_\theta(\theta) \equiv \mathbf{e}_z.[/tex] We can then adopt the convention that [itex]S[/itex] increases in the direction of increasing [itex]\theta[/itex] to remove the absolute value signs.
pasmith said:
To derive the second, in the case of motion in the (x,y,0) plane we can calculate 12‖r×v‖ either in cartesians or in plane polars using the standard formulae r=rer(θ)v=r˙er(θ)+rθ˙eθ(θ) where er(θ)×eθ(θ)≡ez. We can then adopt the convention that S increases in the direction of increasing θ to remove the absolute value signs.
Thank You so much @pasmith !
##\vec r = x \hat i + y \hat j##
##\vec v = v_x \hat i + v_y \hat j##
##\vec r \times \vec v = (x v_y - y v_x) \hat k##
##\frac {dS} {dt} = \frac 1 2 (xv_y-yv_x)##
Is the above right?
Yes, the above is right
  • · Replies 21 ·
  • · Replies 30 ·
  • · Replies 16 ·
