What is the derivative of the square root of 2x using the chain rule?
  • Thread starter Thread starter chebyshevF
    Chain Chain rule
The problem involves finding the derivative of the function f(x) = √(2x) using the chain rule, which is a topic within calculus focusing on differentiation techniques.
  • Conceptual clarification, Mathematical reasoning
  • Participants discuss the application of the chain rule, with one attempting to set u = 2x and deriving expressions for dy/dx. There is also a focus on the interpretation of the expression and the placement of the square root in relation to the constants and variables involved.
The discussion is ongoing, with participants questioning the correctness of the original solution and clarifying the notation used in the expressions. There is an exploration of different interpretations regarding the placement of the square root and its implications for the derivative.
There is some confusion regarding the notation and whether 2x is equivalent to 2*x, which is being examined in the context of the derivative calculation.
chebyshevF
Find the derivative of:
f(x)=[tex]\sqrt{2x}[/tex]
So using the chain rule: [tex]\frac{dy}{dx}[/tex]=[tex]\frac{dy}{du}[/tex].[tex]\frac{du}{dx}[/tex]
Isn't it just a simple matter of setting u=2x, therefore du/dx=2, and y=[tex]\sqrt{u}[/tex]=u^1/2, therefore dy/du=1/2 * u^(-1/2)
Therefore dy/dx = 1/2 *2x^(1/2) . 2
finally = 2x^(-1/2)
Is this correct? The solutions say that the answer is 1/2 * sqrt(2x)^-1/2
So long as your answer is (2x)^(-1/2) not 2*x^(-1/2) then you are correct and the solution is wrong.
Thanks.
But isn't 2x the same as saying 2*x ?
chebyshevF said:
Thanks.
I just wanted to be clear that the square root applied to the 2 and the x and not just the x hence the brackets
chebyshevF said:
Thanks.
Yes, but (2x)^{1/2} is NOT the same as 2x^{1/2}!
  • · Replies 105 ·
11K
  • · Replies 25 ·
