What is the difference between global and local maxima and minima?
  • Context: High School
  • Thread starter Thread starter dev70
    Global Maxima Minima
The discussion centers on the differences between local and global maxima and minima in mathematics, exploring both definitions and examples. Participants engage with the concepts theoretically and through graphical representations.
  • One participant asks for the basic difference between local and global maxima and minima.
  • Another participant provides a metaphorical example comparing local maxima to the tops of mountains in different countries and the global maximum to the highest peak, Mount Everest.
  • A participant emphasizes the mathematical definitions, stating that a global maximum is the absolute highest value of a function over its entire domain, while a local maximum is the highest value within a specific interval.
  • Examples are given, such as the function f(x)=x^3+x^2-17x+15 having no global maximum, while g(x)=sin(x) has global maxima at specific points.
  • There is a mention of local maxima occurring at various peaks in a graph, with one peak being identified as the global maximum.
Participants present varying perspectives and examples, but there is no explicit consensus on a singular definition or understanding of the concepts discussed. The discussion remains open-ended with multiple viewpoints expressed.
Some mathematical examples provided may depend on specific intervals or domains, and the definitions of maxima and minima may vary based on context. The discussion does not resolve these nuances.
dev70
hi pf, this is my 1st math question. i am a undergraduate grade 12 student and my question is
what is the basic difference between local maxima minima & global maxima minima?
hi dev70! :smile:
the top of k2 is a local maximum
the top of mount everest is a global maximum :wink:
mathematically, what's the difference?
tell us what you think, and then we'll comment! :smile:
(if necessary, do some research on wikipedia etc :wink:)
If I may interject here. Take a look at this graph http://www.stat.purdue.edu/images/Research/Profiles/velocityReal2.jpg you'll see many humps (maxima). All the humps are local maxima in the sense that they are all peak values at their respective intervals. However, the one at around 0.58 is crowned the global maximum because not only is it the peak in its respective interval, but it is the highest of all the peaks in the entire function.
Take the everest example, you're asked to find the highest peaks in each country around the globe, and call each a local maximum. Then choose the highest peak of all, and call it a global maximum.
The same logic follows for minima.
I hope you found my answer helpful.]
A global maximum is the absolute greatest value that a function reaches on its domain. For example, the function [itex]f(x)=x^3+x^2-17 x+15[/itex] has no global maximum, but [itex]g(x)=\sin(x)[/itex] has global maxima at [itex](\frac{\pi}{2}+2\pi n,1),\,\,n\in\mathbb{Z}[/itex]. A local maximum is the greatest value that a function reaches within a subset of its domain. For example, the local maximum of [itex]f(x)[/itex] on the set [itex]\{x\colon -5<x<1\}[/itex] occurs at [itex](-\frac{1}{3}(1+2\sqrt{13}),\frac{1}{27}(560+208\sqrt{13}))[/itex], but [itex]g(x)[/itex] has no local maximum on the set [itex]\{x\colon 0\leq x<\frac{\pi}{2}\}[/itex] (it would have one at the right endpoint, but that is not included in the set).
  • · Replies 17 ·
