What is the difference between these two works ?
  • Level: Undergrad
  • Thread starter variation
    Difference Works
4 replies · 3K views · last reply
variation
Some examples in textbook make me confused when these two works are discussed at the same time.
One of the works is the (mechanical) work in work-energy theorem:
[tex] \Delta K = \sum_iW_i,[/tex]
where [tex]K[/tex] is the kinetic energy and [tex]W_i[/tex] was the work done by the [tex]i[/tex]-th force.
The other is the (thermodynamical) work in the first law of thermodynamics:
[tex] \Delta U = Q + W,[/tex]
where [tex]U[/tex] is the internal energy of the system, [tex]Q[/tex] is the heat transfered, and [tex]W[/tex] is the work done on the system by surroundings.
Are the two works the same when we want to use work-energy theorem and the first law of thermodynamics at the same time?
Can anyone give some criterion to distinguish these two works ?
Thank you .
Hi Variation:
You might want to refer to the overall energy balance equation:
dPE + dKE + dU = Q - W
Now the first equation have certain assumptions, that the change in potential energy is zero (such as it is on a flat surface) and the change in internal energy is zero (no state changes, or temperature and pressure changes). This is your classic pulling a block on a flat surface problem.
The second equation, you have thermodynamic work. You have state changes, and this assumes that no mechanical energy, potential energy or kinetic energy. So basically on a flat surface and not moving. A classic problem is the cylinder with the piston. You put it near the flame and it would expand. Flame provides heat (Q) and expansion is work (W)
I hope this helps.
This two works are barely the same. Let me give you the simplest example. Internal energy is
[tex]U = U(S, V, N)[/tex]
with
[tex]dU = TdS - PdV + \sum \mu dN[/tex]
[tex]-PdV = dW[/tex]
being the elementary mechanical work.
You get precisely the same elementary work with mechanics of continuous media (consider the simplest case of a diagonal stress tensor [tex]\sigma_{ij} = -P \delta_{ij}[/tex]).
