What Is the Electric Field of a Coaxial Cable?
The discussion revolves around finding the electric field of a coaxial cable consisting of a cylindrical metal sheath and a conducting wire, both carrying the same charge per length. Participants are tasked with determining the electric field in three distinct regions based on the distance from the central axis of the wire.
  • Participants explore the implications of the charge distribution on the electric field, questioning whether the charges cancel out in certain regions. There is discussion about the appropriate Gaussian surface to use for different regions and how to express distances between the inner and outer conductors.
The conversation is active, with participants providing hints and guidance on setting up Gaussian surfaces and applying Gauss's Law. There is an ongoing exploration of the implications of charge distribution and the location of charges within the conductors.
Participants are navigating the complexities of applying Gauss's Law to a coaxial cable setup, with some uncertainty about the contributions of charge per length and the geometry of the problem. The discussion reflects a mix of understanding and confusion regarding the electric field behavior in different regions of the coaxial cable.
Kot
A long coaxial cable of length L consists of a cylindrical metal sheath of radius b surrounding a conducting wire with outer radius a. The sheath and wire are given the same charge per length +Q/L. Find the electric field in terms of distance r from the central axis of the wire in the regions 0 < r < a, a < r < b, and r > b.
Gauss' Law ∫EdA = Qino
I am not really sure how to do this problem but I think I have an idea. I have to find the electric field in terms of distance r of three different regions 0 < r < a, a < r < b, and r > b. Since the cable and metal sheath have the same charge per length, wouldn't they both have the same charge and cancel out? Could someone explain how I can find the Gaussian surface for the first region?
Hi Kot! :smile:
For r > b, yes
So the electric field there is … ? :wink:
(for r < a) Why don't you just use a cylinder of radius r ?
For r > b, the electric field wouldn't completely cancel out since I was given an arbitrary a and b.
For a < r < b, I am still not sure what radius to use. How can i express a radius that is between a and b?
Hi Kot! :smile:
But the question says that the charges per length are equal. :confused:
Just call it r.
What do you get?​
It's charge per length is equal but doesn't the length of a and b also contribute to the electric field?
For a < r < b, if I have a Guassian surface (cylinder in this case) then I get:
EA = ρV / εo
E2∏rL = ρ∏r2L / εo
E = ρ / 2 εo
charge per length is what it says
the radius (a or b) has nothing to do with it
ρ∏r2L / εo
what is ρ ? :confused:
you seem to be calculating a volume
the charge is a surface charge, on two cylindrical shells
Oops,
EA = σA / εo
E(2∏rL) = σ(2∏rL) / εo
E = σ / εo
where σ is the surface charge density of the cylinders. Is this correct?
Kot said:
σ(2∏rL)
what is this supposed to be? :confused:
(and what does 2πr have to do with it?)
σ(2∏rL) is σA, the surface charge density of the cylinder. Since I need to find the electric field, I used Gauss' Law ∫EdA = Qenclosed / εo . I replaced Qenclosed with σA.
But the surface charge depends only on L :redface:
(and now I'm off to bed :zzz:)
Could I get a hint on how to do this problem?
(just got up :zzz:)
If …
… then what is the total charge inside a cylinder of length L and radius r (a < r < b) ?
Would the total charge inside a cylinder be Qenclosed = E2∏rLεo ?
why?? :confused:
(and what is E ? and what happened to Q ?)
I used Gauss's Law. The E is the electric field and Q is the total charge enclosed inside the cylinder.
Start by setting up a Gaussian surface inside the inner wire ( r < a). What is the shape of the surface?
The Guassian surface is a cylinder. Since it is symmetrical I don't have to do the integral, I can use EA = Qenclosed / εo. The area of the cylinder would be 2∏rL.
Right. But what is Qenclosed?
If I let the Guassian surface (cylinder) to be the same length as the cable, Qenclosed would be the same length as the cable L. I can rewrite Q as λL. Is that right?
Well, where do you think the charges are located on the inner wire?
Remember, the cable's inner and outer conductors are just that - conductors.
Since it is a conductor, wouldn't the electric field be zero?
Yes, but my question was, where are the charges located? The problem said you have Q coulombs per meter charge sitting somewhere in/on the inside wire.
The charges are located at the center of the Guassian cylinder.
No. The charges all repel each other & so want to get as far away from each other as possible. So where would that be?
On the surface of the Guassian cylinder?
The Gaussian cylinder is a construct. You can place a gaussian cylinder any way you want, so that can't be the answer. Besides, the charges have to rest on some kind of matter, not some fictitious surface. Specifically, they have to be somewhere on/in the wire, since that's what you were given.
I can't see why this matters. Doesn't Gauss's Law apply to a charge inside a chosen surface. If I chose the Guassian surface to be big enough, it would contain the charge. Since the charges are repelled by each other and cannot be on the Guassian surface, it would be on the surface of the wire?
Contain it, not hold it.
Your answer is now correct: the charges all reside on the outer surface of the inner wire at r = a.
So now place your gaussian cylinder with radius r < a, how much charge does it hold?
Well since all the charges reside on the outer surface r=a, and the chosen Guassian surface has r<a. The Guassian surface does not hold any charge.
  • · Replies 16 ·
  • · Replies 16 ·
