What is the electrostatic force field?
The discussion revolves around the nature of the electrostatic force field and the underlying mechanisms that mediate interactions between charged particles. Participants explore conceptual, theoretical, and philosophical aspects of electric fields, comparing them to gravitational forces and questioning the physicality of these interactions.
  • One participant expresses confusion about the nature of the force between charged particles, seeking a deeper explanation beyond the term "electric field."
  • Another participant suggests that virtual photons might be a way to conceptualize the interaction, though they express doubt about its legitimacy.
  • A different participant argues that the term "electric field" is often dismissed without proper exploration, contrasting it with the accepted concept of warped spacetime in gravity.
  • Some participants note that both gravity and electromagnetism share similar mathematical descriptions, yet gravity has a more fundamental explanation that has led to more accurate predictions.
  • Quantum Electrodynamics (QED) is mentioned as a potential avenue for a deeper understanding of electric fields.
  • One participant challenges the perceived double standard in questioning electric fields compared to gravitational fields, suggesting that similar inquiries could be made about both.
  • A later reply discusses the electrostatic field as a manifestation of electric charge, emphasizing that what is observed in particle colliders is not a simple representation but rather a complex influence measured by detectors.
Participants express a range of views, with some agreeing on the complexity of the topic while others disagree on the adequacy of existing explanations for electric fields. The discussion remains unresolved, with multiple competing perspectives on the nature of the electrostatic force field.
Participants highlight limitations in understanding and definitions, particularly regarding the physicality of electric fields compared to gravitational fields. The discussion reflects a dependence on interpretations of fundamental forces and the challenges in conceptualizing them.
Fraser MacDonald
I have just covered the electricity unit in my advanced higher physics course, and have happily accepted that a force is created between charged particles. I understand that coulombs law can be used to calculate this force, but here is my question.
What actually is this force between the charged particles? I understand that the gravitational force is the warping of space time, and so I can accept how the gravitational "pull" is generated, however I am not aware of any changes to the fabric of space that causes the interaction between charged particles. What is this force that mediates between the gap that causes the attraction/repulsion of charges?
When I search "what is an electric field?", the only answer I get is that it is a "fundamental force field", and when I have seen similar questions asked in forums the general answer is "Its a fundamental force, so just accept it".
Could someone explain what is it that these charges are actually emitting that causes the interaction between point charges, without just saying an electric field. Thank you!
Virtual photons? I doubt that is a legitimate answer but I don't know what you expect. It's like asking why electrons don't crash into protons... because these invisible, fundamental forces control the universe.
Umm, that is what it is. How do you expect anyone to answer a question where you already know and reject the answer?
We can describe what it does, and how it relates to other things, and its properties. Then, referring to all of that, we give it a name.
But for gravity we know that the force that causes the attraction is really just the warped space-time, so I can easily accept what is happening between the masses that causes the attraction. However, with electric fields, there is nothing physical that is happening between these charges. What is the invisible force? What is actually bringing about the interaction between them? I am really struggling to conceptualise such a force field and what it really is.
Stare at a magnet hovering on a superconductor for a while and ponder it.
haha! I often confuse myself by asking strange questions like these that perhaps don't make complete sense. It drives my teachers mad. It's great
They don't take lightly to that, here. Everyone who replies is trying to give you the best, most complete answer they can, within mainstream physics.
This is a double standard. Why is the word “warped spacetime” acceptable but the word “electromagnetic field” not? They are just words. In both cases the words refer to a set of differential equations and experimental measurements. If one is acceptable then so is the other.
I think OP has a good question. Coulomb's Law and Newton's Law of Gravity have the same form but with gravity we've gone a step further to explain the force in a more fundamental way that has led to more accurate calculations and predictions of new phenomena. Is it possible that will be done some day with the electric field?
Try QED.
I googled it and got latin translation of "Quod erat demonstratum": "What was to be demonstrated" or "Quantum Electrodynamics" (which was what I intended):woot:
Yes! It is the fact that we can explain gravitational fields in a more fundamental way than the electric field. The two are so similar mathematically, I wasn't sure if there was an equivalent deep explanation for Electric fields.
Quantum Electrodynamics.
Zz.
actually
Sometimes I think the forum should refuse to post messages with the word "actually" or "really" in the title. You can always follow an answer with "but what is it really?" (And then "but what is it really really?" Turtles all the way down.)
I think you need to re-evaluate your starting point here. "Advanced higher physics" certainly sounds impressive, but it's really a very, very elementary presentation of the subject. The mathematical description of both gravity and electromagnetism is identical - something called classical field theory. The words we used to describe it are, well, just words. If you think some of these words imply one theory is somehow more fundamental than the other, that's your reaction to those "just words", not anything physical.
That still seems like a double standard. Why aren’t you asking “what actually is curved spacetime really”? Why does the mere words “curved spacetime” eliminate all further inquiry? All of the questions you are asking about electric fields could be asked about curved spacetime too, but you don’t. You just back off at the word “curved spacetime”
You seem to hold electromagnetism to an oddly different standard than gravity.
That is a hard question to answer, @Fraser MacDonald. The electrostatic field is considered in our standard physics merely as the manifestation of an electric charge. The best way we have to see fundamental electric charges like electrons is through particle colliders. And when we "look" at those charges through the detectors of the apparatus, what we see is not little spherical balls like we are made to think. Such image is merely to facilitate our visualization. What we do see is a spreading of electrical influence, which is measured by the detectors (sensible to electromagnetic manifestations), the finger prints of the field. That is an "electron".
This is highly misleading. It gives the impression that for a particle such as "electron", it is nothing more than "charge" or the electric field that it emanates.
An electron is more than its charge or its associated electric field. In spintronics, its magnetic moment is of utmost importance. And since we are referring to particle colliders, its mass, or more importantly, its momentum, is also part of its properties. Any of these properties (spin and momentum) can be used to detect an electron. It is not just restricted to its charge/electric field.
Zz.
Zz.
I agree @ZapperZ, the definition I gave is merely to give a sense about the electric field and what it is.
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 21 ·
17K
