What is the Group Velocity of a Quantum State?
Relativeee
Ok hello, The problem is there is a system in the state characterized by
\Psi(x,t) = \int dk e^(ikx)e^(-iwt)f(k), which is the time dependent representation of a wave packet, where individual waves travel with velocity
vp = w/k and f(k) = (2*\alpha/\pi)^(1/4)e^(-\alpha*k^2). The problem is to find the group velocity(associated with the state) along with the probability for measuring the particle at time t=t0>0 at position x=x0>0 and also probability per unit length at same position. Also what exactly is the meaning of these results?
Ok so the first part, the idea in the book was if f(k) has a peak at k = k0 and w is a function of k then there can be an expansion of w around the point k = k0
w = w(k) = w0 + (dw/dk)(k-k0) = w0 + vg(k-k0), where vg = (dw/dk) at w = w0
Ok now to show that vg is group velocity, we can note that since dominant contributions of \Psi(x,t) come from region where k = k0 the above expansion can be kept at first order in (k-k0) and so from the integral we can write kx - wt = kx - [w0 +vg(k-k0)]t
and therefore the integral can be written as
\Psi(x,t) =e^[i(k0vg-w0)t] \int dk e^[ik(x-vgt)]f(k)
\Psi(x,t) =e^[i(k0vg-w0)t]\Psi(x-vgt,0) so we note that the packet travels as a whole velocity vg that maintains the same probability density and therefore we can call vg the group velocity.
So that was i was thinking they were asking for the first part. For finding the probability at x = x0 > 0 and t = t0> 0 is it enough to say that the probability is
|\Psi(x0-vgt0,0)|^2? I am not quite sure on the probability per unit length or The exact meaning of these results. If anyone could give some insight that would be great thanks alot
Anyone has a solution?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
