What is the Inverse Laplace Transform of e^(-sx^2/2)?
The discussion revolves around finding the inverse Laplace transform of the function e^(-sx^2/2). Participants explore various methods, including the convolution theorem and properties of Laplace transforms, while grappling with the implications of using the Dirac delta function in their calculations.
  • Mixed
  • Participants discuss using the convolution theorem and express uncertainty about the inverse Laplace transform of e^(-sx^2/2). There are questions about the difficulty of integrating with the Dirac delta function and whether convolution is the best approach. Some participants suggest using established properties of Laplace transforms instead.
The discussion is active, with participants offering insights and clarifications about the properties of Laplace transforms and the role of the unit step function. There is a recognition of the need to carefully consider the implications of shifting properties in both the time and s-domains.
Participants are navigating the complexities of the problem, including the definitions and behaviors of functions for t < 0, as well as the specific conditions under which the inverse Laplace transform is valid. The presence of the Dirac delta function and its integration properties are also under scrutiny.
Haku
Find the inverse Laplace transform of 1/s^2 * e^(-sx^2/2)
Laplace convolution theorem equation.
My attempt at finding this was via convolution theorem, where we take F(s) = 1/s^2 and G(s) = e^(-sx^2/2). Then to use convolution we need to find the inverses of those transforms. From a table of Laplace transforms we know that f(t) = t. But I am sort of struggling with e^(-sx^2/2). My 'guess' is that the inverse Laplace transform of e^(-sx^2/2) is δ(t - (x^2)/2). This is from the fact that the inverse Laplace transform of e^sc is δ(t+c). But then integrating this in the convolution integral proves difficult.
Am I on the right track or should I use another method of finding the inverse Laplace transform of 1/s^2 * e^(-sx^2/2)?
Note: Here I have used * to denote multiplication and not convolution.
It seems a bit puzzling to me that you say the presence of the Dirac delta function makes evaluating the integral difficult. I find it makes evaluating integrals simple and straightforward. Can you elaborate more about why you find it difficult?
Also, are you wedded to using convolution? A straightforward application of the established properties of Laplace transforms will get you the answer to the problem.
I am happy to use any method, preferably the easiest too.
The reason I said it made it difficult is because you would have to evaluate the Dirac delta function at ((t-T)-x^2/2) would you? (Where T is tau).
Don't let the argument of the delta function confuse you. You have
$$\delta\left[(t-\tau) - \frac{x^2}{2}\right] = \delta\left[\left(t - \frac{x^2}{2}\right)-\tau\right].$$ You can treat the stuff in the parentheses as a constant since you're integrating with respect to ##\tau##.
Also, you should be a little careful here. The inverse Laplace transform of ##F(s)## is ##f(t) = t u(t)## where ##u(t)## is the unit step function.
Ah okay, I will try to integrate that now.
As for F(s), why would it be tu(t)? the Laplace transform of t is 1/s^2. So why would the inverse of that change the original function?
Also what was your easier way to calculate the inverse?
Thank you!
If you recall, when you calculate ##F(s)##, you calculate
$$F(s) = \int_0^\infty t\,e^{-st}dt.$$ All information about ##f(t)## when ##t<0## doesn't contribute to ##F(s)##. Hence, when you say the inverse Laplace transform of ##F(s) = 1/s^2## is ##f(t) = t##, it's really only true for ##t>0##. Quite often, this detail doesn't matter as it's understood that ##t>0## (for example, when solving a differential equation). In problems like this, where the factor ##e^{-as}## represents a shift in time by ##a##, it becomes important to remember that ##f(t) = 0## for ##t<0##. When you shift the function to the right by ##a##, the result is ##0## for ##t<a##. (Note this is the simpler way: use the time-shift property of Laplace transforms.)
Another way to see this is to try calculating the Laplace transforms of
$$f(t) = \begin{cases} t-a, & t \ge a \\ 0, & t<a \end{cases}$$ and
$$g(t) = t-a$$ where ##t>0##. You'll see ##f## yields the Laplace transform ##e^{-as}/s^2## whereas ##g## doesn't.
Ahhhh yes, it is because the lower limit of the integral is 0 right?
So in this case you get; $$F(s) = \int_0^\infty t\,e^{-st}dt.$$ = 1/s^2
And we have the s-shifting variable e^-as, where as = sx^2/2 right?
But in my definition of the s-shifting prop we used e^at as the shifting 'variable', in this case we have t = 1 but also an x term so how does that all fit together?
Also, do we consider the case of t < 0 because once it is shifted, then it is no long t < 0, it becomes t < a, which could be > 0 right? Since the actual t < 0 would not matter since t denotes time right?
Thanks!
There are two shifting properties: one in the time domain and one in the s-domain. You're mixing them up.
Even with the shift, your solution needs to be defined for ##0 \le t \lt a##. That's why the unit step function is included.
Ah yes I see,
I think I understand now, so by the second shifting property we have that the inverse Laplace transform of e^(-sc)F(s) = f(t-c)H(t-c), and in this example c = x^2/2 and F(s) = 1/s^2.
So we get the inverse Laplace transform of e^(-sx^2/2)•1/s^2 = f(t-c)H(t-c), where c = x^2/2 and H is the unit step function.
That means the original function u(x, t) = the inverse Laplace transform of e^(-sx^2/2)•1/s^2 = f(t-x^2/2)H(t-x^2/2) = (t-x^2/2)u(t-x^2/2) right?
Thanks!
It's not correct to write "e^(-sx^2/2)•1/s^2 = f(t-x^2/2)H(t-x^2/2)" but you got the idea.
Ah I see.
Thank you! Helped a lot!
