What is the Kinematics of a Particle Leaving a Ledge?
The discussion revolves around the kinematics of a particle that leaves a ledge at a height of 4 meters, impacting the ground after 1.2 seconds and landing 2 meters away horizontally. Participants are exploring various aspects of projectile motion, including the original velocity, final velocity, and maximum height achieved by the particle.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of equations related to projectile motion to determine the original and final velocities, as well as the maximum height. There are questions about the validity of specific equations and assumptions regarding the angle of launch. Some participants suggest using horizontal and vertical components of motion to derive necessary values.
The discussion is active, with participants offering various approaches to the problem. Some have provided equations and methods for calculating components of motion, while others express confusion about the relationships between the variables involved. There is no explicit consensus on the best approach yet, but multiple lines of reasoning are being explored.
Participants are working under the constraints of a homework assignment, which may limit the information available or the methods they can use. There is also a discussion about the assumptions made regarding the angle of projection, which has not been specified in the problem statement.
jjones1573
A particle leaves a ledge at a height of 4m and hits the ground at 1.2s later landing 2m away horizontally.
find:
The original velocity
The final velocity
The max height acheived
So I know that for the original velocity:
Vo = D * SQRT(g/2H)
where:
Vo = original velocity
D = how far it landed
g = gravity
H = original height
So for my initial velocity with the above equation I get:
Vo = 2 * SQRT( 9.8 / 2 * 4)
= 2.1m/s
Is this method correct?
I'm not sure how to find the final velocity before it hits the ground
Also the max height is surely the original height of 4m as its going down from here. suppose the particle jumped from its position on the ledge could I figure out a max height.
One last thing. could anybody show me how to find an acceleration vector of a projectile. I know how to get the velocity vector using arctangent but I can't find anything on acceleration vectors.
thanks so much,
find:
The final velocity
The max height achieved
Well I'm presuming the particle is experiencing horizontal projectile motion.To find the original velocity I would use dx=vx+1/2a(t)2, where x are the horizontal problems given in the question, such as the particle landing 2 m away horizontally, time can be used in both x and y component equation.
The final velocity would be the velocity upon impact.. now you can use v2y2=v1y2+2ad. Because of the horizontal velocity, v1y would equal zero, simply plug in the other numbers.
You can easily find the maximum height after finding the first two parts, try it yourself :P.
No, that is wrong.
Vo = D * SQRT(g/2H)
where:
g = gravity
H = original height
For which situation is this true? Doesn't it depend on the angle on which it is thrown?
I said that because there wasn't an angle being given.
Enough information is given to find the angle
Oh I had found that equation on a thread on yahoo answers where someone had posed a similar question and that was the answer given. So how could I find the angle or is there some resource you could point me to where I could find this?
Let the velocity be u and angle be x.
ucosx.t = 2
and
1/2gt^2 - usinxt = 4
From here use t=1.2 to get usinx, ucosx.
sorry I'm kind of confused here. Do I need to find the initial velocity first in order to do this?
No, you don't. Obtain usinx and ucosx as above. Divide them to get tanx. You have got the angle in tan
Ah ok I get it thanks so much!
so to obtain initial velocity do I just find the components. when I get usinx and ucosx I divide them by sinx and cosx and then calculate the intial velocity from these x and y components
Also when calculating the max height I use Viy * t + (0.5)at^2 I use this equation when the projectiles height remains the same at the intial and final stages but in this instance should I add my initial height to the answer or do I need to do somehting else?
  • · Replies 38 ·
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 38 ·
