What is the largest capacity battery I can charge from my 2.5kW solar panels?
18 replies · 3K views
bob4866
I have solar panels fitted, with a capacity of 2.4 -2.5 kW. I am considering buying lithium battery storage for evening use. What would be the largest battery system I could charge from this setup?
:welcome:
Assume:
  1. Your panels produce close to full power for 5 hours per day.
  2. You consume zero during those 5 hours.
2.5*5 = 12.5 kWh of batteries is the largest amount you can charge.
anorlunda said:
:welcome:
Thanks anorlunda, very fast reply with a simple, easy to read answer. I have a device that records hourly readings from my panels on a spreadsheet so I can now get an accurate figure before committing to a battery system.
Assume:
You can go larger, though you won't get them charged in a single day if you run them right empty.
If you use much bigger capacity (but don't go wild!) and you use less than full capacity on most nights then you would have extra for rare occasions.
Note: the 'capacity' of a battery is not a well defined figure and many are advertised over-optimistically. Look at this link to see what I mean. A rule of thumb for Lead Acid Cells is that you can use only half the rated capacity is you want a good battery life. Lion cells are better behaved than that but you need to be careful with those shiny new batteries you have bought. Buying 'more than enough' could make good economic sense as it can avoid damaging them by discharging them too much.
If this is a serious exercise, a proper battery management system would be worth while considering which would keep a running total of charge / discharge and prevent damage. Much cheaper than a replacement set of batteries.
Thanks for the replies Rx7man and Sophiecentaur. This is a serious exercise as local sales reps use sales techniques quoting 3kWh, 7kWh and 10kWh battery packs, hence the question. I would definitely buy a management system, some of which have the option to trickle charge low batteries overnight when the cost is lower in the UK.
There's the issue of actual kWh available every day. That can be very disappointing if you compare it with the peak kW output of your PV panels.
If you are considering co-existing with the Grid and the possibility of supplementary charging then that could well be the cheapest solution and you could live nearer the edge of performance, having your backside covered by the Electricity supplier.
I would be interested to know how you plan to use your PV energy if you are not going On Grid with it. The UK government have been talking about encouraging battery development for local storage but it's still very expensive, as far as I can see. PV was, for a time, the obvious way to go but the Feed In Tariff is rubbish now. Pity there's not more know-how in Government circles.
Please enlighten us. What happened to the Feed In Tariff in the UK?
I have a friend who had the right house at the right time and the right money. The feed in tariff at the time was ludicrously high (to attract customers and to make Blair look good). My friend's FIT income pays for all his house services. And all the other Electric supplier's customers are subsidising him. Now I have an appropriate house and some cash, the deal is rubbish as the FIT is falling and falling. There seems to be no incentive any more.
Ah yes. Incentives are very difficult to right size when politicians get involved.
What's your typical consumption?
FIT was around £0.44 per kWH in 2010 but is now down to <£0.04 per kWH I think.
Stand rate electricity (eg to buy from the grid) is around £0.18 per kWH so storing excess and using it yourself at night saves you around £0.14 per kWH
I think the most reasonable FIT would be the same as the cost to buy.. the "subsidy" would be the cost of maintaining the grid... In our case we're looking at hydro generation for about 2kW 24/7.. If the costs were symmetrical for buying and selling, I'm sure that would cover our needs quite nicely without the need to have expensive storage systems
Once you have a reservoir of water, that's the best and cheapest storage medium.
terrain doesn't allow for storage, but there is a reasonably steady flow
Bad luck. But good luck that you actually have water flowing through! I have never had that good fortune. From what you say, you probably have a large flow with not much head of water (?).
Water storage can be 'good value' when it's available. A tank of water, 2.5X4m and 1m deep, at a height of 10m will store about 1MJ, which is worth about 2.7kWh, which is almost half the capacity of a Tesla Powerwall Battery. There would be only one Energy Conversion involved (then there's the 80% efficiency for a small installation). Lifetime of an installation would be a lot better than Lion battery life and you would need the original generator in any case.
All those parameters to consider - no wonder people pay for some money grabbing 'consultant' to take away the brain ache.
This is off I think. $$1MJ =.27kWh$$
  • Love
Whoops - cheers.
Cheaply produced iron would be about 7 times that capacity. An embarrassing weight to deal with all at the same time but the lifting and lowering of the load could be 'a bit at a time' which is the big advantage of a liquid. But almost any mechanical system would compete with needing to provide Lithium.
The future will be energy management systems. I heard of one person in England that gets paid to turn his water heater on at night to stabilize the grid, it is internet connected. Solar systems generate power at the wrong times to be much use to the grid. Many solar homes now have monitors to look to see when power is being exported and use that to turn on devices like water heaters. Laundry, dishwashers air conditioning and heating can be scheduled to turn on at these times. I live in a town where they are not allowing any more solar farms. They don't have the transmission line capacity to get the power out. This is another interesting situation created by politics. In the 70's farmers got tax breaks to deem the land for farming so it could never have housing built on it. Solar farms a farm. In California a bee is legally a fish. I love politics.
Not really, They just get endangered species protection under the fish act, it was the easiest place to put them
and yes, 1MJ is 0.277 KWhr
