What is the Limit of the Partition Function in the Low Temperature Regime?
quanlop93
Ground state energy is set at 0.
E_n=\left(1-\frac{1}{n+1}\right)\in with no degeneracy (\Omega(n)=1); (n=0,1,2...)
Write down the partition function and look for its limit when kt \gg \in\\ kt \ll \in
Partition function for this is Z=\sum_{n=0}^\infty e^{-\beta\left(1-\frac{1}{n-1}\right)\in}
Consider Z when ##kt \ll \in## then ##\beta e \gg1## then ## e^{-\beta e} \rightarrow 0## This leads to the whole summation will go to 0. But we know that at low temperature, Z always goes to 1.
I have tried to calculate the summation but this series is divergent.
How can I change the calculation to reach Z =1?
I agree - if you have an infinite number of energy levels, bounded above by \epsilon, then the partition function diverges.
What happens if you single out ##n=0##?
Likes quanlop93
With n = 0 \left(1-\frac{1}{0+1}\right)=0 then Z=1 in two cases. But its supposed to be 1 just in the case that the temperature is low kt\ll\epsilon
I have tried some direct methods to find the limit of this function, but it turned out that the function is divergent. Then all of them became useless.
What I meant is take ##n=0## out of the sum in the low T limit, and you recover ##Z=1## as expected.
Likes quanlop93
Got it now. Thank you.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
