What is the Limit of the Partition Function in the Low Temperature Regime?
The discussion focuses on determining the limit of the partition function in the low temperature regime, specifically when kt is much less than ε. The partition function is initially defined, but when evaluated under low temperature conditions, it appears to diverge due to an infinite number of energy levels. A key insight is that by isolating the ground state (n=0), the partition function simplifies to Z=1, which aligns with expectations for low temperatures. Participants emphasize the necessity of considering the ground state to resolve the divergence issue. Ultimately, the consensus is that focusing on n=0 allows for the correct evaluation of the partition function in this context.
quanlop93
Ground state energy is set at 0.
E_n=\left(1-\frac{1}{n+1}\right)\in with no degeneracy (\Omega(n)=1); (n=0,1,2...)
Write down the partition function and look for its limit when kt \gg \in\\ kt \ll \in
Partition function for this is Z=\sum_{n=0}^\infty e^{-\beta\left(1-\frac{1}{n-1}\right)\in}
Consider Z when ##kt \ll \in## then ##\beta e \gg1## then ## e^{-\beta e} \rightarrow 0## This leads to the whole summation will go to 0. But we know that at low temperature, Z always goes to 1.
I have tried to calculate the summation but this series is divergent.
How can I change the calculation to reach Z =1?
I agree - if you have an infinite number of energy levels, bounded above by \epsilon, then the partition function diverges.
What happens if you single out ##n=0##?
Likes quanlop93
With n = 0 \left(1-\frac{1}{0+1}\right)=0 then Z=1 in two cases. But its supposed to be 1 just in the case that the temperature is low kt\ll\epsilon
I have tried some direct methods to find the limit of this function, but it turned out that the function is divergent. Then all of them became useless.
What I meant is take ##n=0## out of the sum in the low T limit, and you recover ##Z=1## as expected.
Likes quanlop93
Got it now. Thank you.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
